switch issues??
93_sr5_4x4
ok so here's my situation! my runner is rebuilt, and it has power windows in the rear but manual in the front! is this normal? cause i would figure the front should be power as well?, now my problem is the window lock button on the center console doesn't work along with the rear window up and down switch but the window will work from the rear with the key inserted! i took a test light to the plugs connectors after i disconnected them and got no power going to the plugs! now the guy i bought the truck off of said there is a heater core underneath the center console for the back temp controls and that was leaking and it blew the headgasket! so they must of had to replace that i'm just curious if something is unplugged further down the way that could be restricting the power? something forgot to get hooked back up? i'm hoping anyway! so the next question is how hard would it to re-wire it if i need to? i'm pretty good with basic wiring, like installing aftermarket stereo's and subs and amp installs would this be a task for the pro's? and have any of you ran into the same problem?? any help will be appreciated! thank you in advance!..... hope i can get this fixed would like to roll down the rear window from the cockpit!, it's just an inconvenence running to the back everytime
Jhunt
