SWitchPro 9100 control panel
WhiteRubi
Hey guys,
just recently ordered a SwitchPro 9100 and about the only solution i can find for mounting the control panel is SDHQs that mounts it left of the steering column. Has anybody mounted it in the open slot below the AC controls and below the USB/12v panel?
I have the SDHQ mount
I think it is a great location
1. Easy to see and access
2. Super easy direct connection through firewall
3. Right next to fuse box for linking into
4. Clean looking with a perfect fit
i have the sdhq mount, its awesome as stated
i modded the center area with the 12 v outlet, you need to pull out the shifter cover and all just to get to where you want to mount the sp9100
just get the sdhq and call it a day, its awesome and in a great location.
I put mine in the cubby at an angle with a piece of angle bracket. The spot by the steering wheel is not bad, but I already have my pedal commander there.
I saw a few really clean installs with it mounted on the headliner in front of the overhead console. I have a sunroof so that wasn't an option for me so I when with the SDHQ mount. If I had it to do over again I would just use my stock one. The only downside to this location is with dark tainted windows at night there is a reflection.
Sent from my SM-N976V using Tapatalk
tuṣṭāva
