T4R 88 first gen OEM alloy rims size and backspacing
SomeDay
Hi!
Please, can you tell me the size of the OEM alloy rims and their backspacing? (T4R first gen 88 Sr5).
I'd like to put 33x10.5R15 BFG in them.
Thanks!
Hi!
Thanks!
I had those on my 86 when I bought it new in 86, 33 10.50's will fit without issue (slight lift needed if i recall correctly for 33's). I ran 31x10.50's for several years on them
pretty sure i have a couple buried in my parts stash, i'll run out and check measurements for you. pretty sure 15x7
mine still have set of roller tires on them, hard to get actual backspacing with the straight edge i had being too long but it looked like a 4" B/S
it said offset is 8 and 15x7
not sure if this thread from Mud will help https://forum.ih8mud.com/threads/toyota-rims.583715/
I stole the photo of my post from that thread! :police:
Your post's better and to the point:
T4R 1988 first gen SR5
OEM ALLOY RIMS
T 15x7JJ-8 DOT
OFFSET 8
Around 4" backspacing
to install 33x10.5R15 BFG tyres in them.
Thank you very much, Dropzone! :thumb3::thumb3::thumb3::thumb3:
3" lift required to clear 35' tires! And I'm almost positive if you use the factory offset that when you hard turn you'll run the frame.
the alloy rims pictured by dropzone, with "offset 8", are not factory size for first gen 4runners. the offset 8 are factory for 2nd gen 4runners. they will fit a 1st, though. the firsts have a 15 offset. you might not get rubbing, as these put the tire farther out.
edit: to clarify, 1st gens have a 15 offset, but no markings indicating that.
wally
wally
Good,
offset 15 OEM alloy rims for first gen.
offset 8 OEM alloy rims for second gen
thanks!
wally
Thank you guys!
I forgot a detail, my T4R has IFS.
T4R first gen SR5 IFS
I can get these:
OEM ALLOY RIMS
T 15x7JJ-8 DOT
OFFSET 8
Do you think they'll rub?
Should I get 8 offset or 15 offset? I know the difference but I don't know which one to buy in the context described above.
Thanks!
pics of factory 1st gen 4runner alloy rims.
15x7JJ-15 DOT
wally
2001ATL
