Taco/FJ lift plus 1/4" spacers all around? Where to buy?
84ability
I'm about to do the Taco TRD Sport shocks and front springs combined with FJ rear springs. It should net about 2" lift up front and .75"-1" in back.
I want to go slightly higher if I can with 1/4" spacers all around, or possibly just fronts, but I do want some positive/stock rake remaining so thinking all around would be best. I need to fit BFG AT KO's in 265/70/17 under there and figure while I'm doing it I might as well add a spacer but I don't want to approach the 3" mark and have to get UCA's.
Does anybody still sell 1/4" spacers for the 4th gen? I'm assuming the 1/4" spacer nets a 1/2" lift. So total lift would be like 2.5"/1.5". Thanks in advance.
toytec and daystar make 1/2" spacers for the front. also OME makes trim packers that give 10mm (~3/8") lift in the rear. seems you would have to go to a lot of trouble and $ for such a small increase in lift!
Thanks! Yeah, saw that as an option after I posted, around $100 for another .75"
Fyi, I got 265/75/16 DTs on my truck with the stock sagging lift (maybe my alignment was just totally jacked?) For like 3 months until I put an icon setup on my truck.
the ko seem to rub a bit more than others when stock. with that lift it might rub but it nothing a little work cant fix
