Tail Light as Turn Signal Kit
Diode Dynamics 5th Gen 4Runner Tail as Turn - Made in USA!
Features
  • Converts your tail light to also function as the turn signal
  • Adds additional backup lights in old turn signal location (optional)
  • OEM tail light connectors for simple plug-and-play installation
  • Made in USA
Overview
Custom Appearance. This kit will convert the LED tail light on your 2014-2019 Toyota 4Runner to also function as the turn signal. This kit will instantly customize your vehicle for a much more modern appearance on the road!
Additional Backup Lights. Also available with the kit, you can convert the old turn signal socket to an extra backup light. With double the number of backup lights, you will add much more visibility when reversing at night. Each kit is already configured to accomplish this; however, you will need to purchase new white LED bulbs. LEDs must be used, instead of standard bulbs, since you will be drawing power from the backup light circuit.
Easy Installation. Using OEM tail light connectors, the kit is 100% plug-and-play and installs in minutes, with no wiring required. While the tail lights still have to be removed from the car, the actual installation time is less than 5 minutes per side.
Experience. After over a decade in business, Diode Dynamics is the most trusted name in automotive LED lighting. Unlike every other LED distributor, we manufacture and engineer products ourselves in the United States, for high quality and fast time-to-market of the newest and brightest LED technologies. We pride ourselves in offering only quality LED products, that will exceed your expectations. Please contact us if you'd like to discuss your lighting project!
In the Box:
  • Two (2) modules for installation on 2014-2019 Toyota 4Runner
  • Two (2) 7443 bulbs for old turn signal location (optional)
  • Two (2) 921 bulbs for existing backup location (optional)
  • One (1) Installation Guide
  • Quantity: Pair (Left and Right Side) Warranty: 3 year warranty Return Policy: 30-day Return with no restocking fee 100% Satisfaction Guarantee
Fitment
Application: Rear Turn, Tail Light, Backup / Reverse Make: Toyota Model: 4Runner Years: 2014, 2015, 2016, 2017, 2018, 2019 Electrical Compatibility: No electrical issues (tested and confirmed)
2014-19 Toyota 4Runner
Tail as Turn™ Module +Backup Module, 1 x 7443 HP48, 1 x 921 HP36 - Stage 1
Tail as Turn™ Module +Backup Module, 1 x 7443 HP11, 1 x 921 HP36 - Stage 2
Tail as Turn™ Module +Backup Module, 1 x 7443 XP80, 1 x 921 XP50 - Stage 3
CLICK LINKS ABOVE - USE CODE
T4R
For Discount
utkrstam
