Tail Light : VLED V3 Triton install
Got2xlr8
anyone know or have a wiring diagram for the tail lights? I'm looking to splice into the turn signal circuit. I have the 7440 kit from VLEDs but in order to get power I can't use the stock 7440 plug (twist lock power) so I will be ordering a pre-wired 7440 socket pigtail.
Ok as per this thread : http://www.toyota-4runner.org/engin...essories/12315-led-tail-lights-installed.html
I figure the 3 wires coming off the primary wiring harness split to -12v and Grnd. so is the center junction that runs to the other 2 lights the ground or the -12v?
how would any of you wiring guru's go about attaching wire? straight solder or is there a spade/clamp that would work better?
don't liek the quick splices. strip it a little and solder in new wire
2001ATL
