Do not waste money getting the rotors turned. This may alleviate the problem, but not for long. You will eventually warp the rotors again. Spend the extra $10 or so to get some new rotors. Maybe extra $30 for new pads. I highly suggest Autozone Duralast rotors and pads.
Anything else I should have done while they are under there?
I will just do the brakes myself.
But they said it would be
$50 balance and rotate (on the GSP9700)
$65 for alignment
$100 to turn all of the rotors and put them back on
I am hoping this will cure my shaking etc...
Do you have a link to those rotors and pads? I wasn't able to locate them for 4Runner.
$65 for alignment
Sorry, on my phone, so it's hard to get the links. But it's super easy. Just go on Autozone.com. Select your vehicle. Then look for the rotors under parts -> brakes. Get the Duralast ones, since they have a 2 year warranty against warping/cracking. The pads are lifetime. I got the Duralast ceramics. $30, iirc.
Also, check to see what size rotors you have. If your calipers say S12, then you have the smaller. If they say S13, it's the bigger. The last time I bought them, the smaller were $25 and the bigger were $50.
Edit: Pick up some brake quiet lube. Most are in orange bottles. It goes on the BACK of the pads.
Thanks. It lists the rotors by rim size...I guess that is what you mean. I have the 15" factory wheels.
Dumb question here but are there even rotors on the rear wheels?
Berry - I've bought Hawks, Axxis, Cobalts, etc, but for a truck, I see no benefits. Sure, the braking principles are there, but it's not a 330, S2000, or other performance cars. My brakes with AZ stuff has been great for the past 3 years and no co
plaints from me. I have yet to experience fade, bite issues, or warping of rotors.
I see. If you have factory 15's then it's definitely the smaller. (which is the same size as my Tacoma). In this case, it's a no brainer to spend $100 for brand new pads and rotors vs just getting the rotors turned.
The rear are drum brakes. Takes more skill to adjust (doubt they need changing). Does your e brake work good?
Are Hawk LTS's better? Perhaps. Make a big difference? Doubt it. Also, what happens if you have issues? You have to send them back, wait for them to evaluate and then send them back to you. That's a lot of downtime. With a local store, you're in and out.
Do you have a the rotors on a 3rd gen? 3 years and no warping? That could be the ticket.
Yes. I had them on there for 2 years on my old 4Runner then sold it to a friend. Still runs great. The ones on my Tacoma is 2 years with no issues. Pads are great, too. I frequent the canyons and use them a lot, too. Funny thing about the pads. The autozone manager told me if they break, bring it back. Also, if they just wear out, bring them back. I said under normal use? Yup. Called two other stores and they said the same. Now I have pads for life.![]()
Just speaking of personal experience and offering my opinions and suggestions-Take it for what it's worth.
The plus with me is I can walk right into TR and buy the items-if there is a problem they take them back just like any other retail outfit. I just like doing business with them-Again personal preference.
I have been told the same thing...just save your receipt!!
Yeah, you are probably right...replacing the rotors is probably going to be my best bet. Now I just need to find someone to do it on the cheap!
My friend, if you have just basic tools, your factory Jack and Jack stands, it is so easy to do. This, I can provide a link.
http://www.4x4wire.com/toyota/4Runner/maintenance/brakes/
4Runner brakes are very easy to work on. You will kick yourself for paying someone else to do it. I'd say it takes the mechanical knowledge equivalent to doing an oil change. Few clips and pins for the pads, and two bolts for the rotors. That easy. Ask if you have questions, but should be pretty straight forward.
