Talk me out of 255/80R17s??
M_RED
It is just about time to yank off the snow-tires and I am leaning heavily towards a 255/80R17 over a 285/70R17. Beyond the aesthetics of a skinnier tire, (which I am ok with as these are going on the more narrow TRD-Pro wheel,) and a heavier load rating (which is probably over-kill and could be a detriment to ride quality, acceleration and mileage) is there anything else I should consider? Seems like I will get away with less trimming too...
Why isn't this option more popular?
Solution
Personally, I would stick to a 285/70-17. Much more selection and ratings. Fits in the spare tire well. If you are way out of town and need a new spare, it is much more likely to find one.
I have Wildpeaks in this size in a SL rated tire and it only weighs 51#’s per tire. They have performed well over a variety of terrain.
[MENTION=95539]SirWilliamGoes[/MENTION]
What are those tires you have on?
The existing tires are the the factory installed 20" P245/60R20. No longer an issue though as I cancelled the order for the Limited and bought a TRD Off-Road Premium expecting delivery mid-April.
Let the best contact patch determine your tire pressure (rather than internet experts)
Choosing Tire Pressure using Static Contact Patch Measurements | Kelvin Tse
You can easily do this with chalk
Tire Pressure Chalk Test - YouTube
Been using similar technique for decades of driving in deep soft sand. The bigger the footprint the better but you can go too low and not gain footprint, but make you more susceptible to loosing a bead seal.
This works for radials
Load the vehicle, including passengers, as it will be in the sand.
Using chalk test, determine pressure for street driving.
Measure the height from pavement to bottom of rim.
Lower pressure until the height is 3/4 of street pressure height.
Note front and rear pressure can be different in both cases, so best to measure each.
TOYO Open Country AT3 255/80 17
TOYO Open Country AT3's, LOVE them in this size. Handle better and feels lighter in the steering, road noise is reduced from my WildPeaks, and SOOOO much better in snow and ice than the WildPeaks. Still a very small about of rubbing on the passer side in reverse, need a BMC. Yeah, wider looks cooler I guess, but I am sold on cookie cutters.
PROS:
1. Drivability
2. My gas milage actually went up a little
3. Able to deflate to 18-20 psi with no concerns
4. Great in winter
5. With my SCS wheels, pretty close to stock weight combined
6. Tall for clearance
7. Quiet
8. Wearing great
9. Balanced no issue, no road force balance needed
10. Fit in the spare location
CONS:
1. A regear might be in my future, highway mostly. Just a little too much gear hunting here in Colorado
PROS:
1. Drivability
4. Great in winter
7. Quiet
8. Wearing great
CONS:
This is great to hear about the Toyo AT3. I'm considering these over the Wildpeaks as my next tire in 255/80. Is the rubbing a result of the wheels?
New tires are on!
Finally got the new tires on, and went with 255/80 Nitto Ridge Grapplers.
They measure in at about 33.25 inches in diameter and other than having to push the front fender liner forward by about 1/2 in, they fit great, and no rubbing at all. At least with the little bit I played around. Later on I'll get to some proper trails and disconnect the sway bars, but I think it is going to be in the clear..
THey ride pretty smooth and are actually much quieter than the blizzaks I run in the winter... I'm quite pleased...
Out of stock at my local tire discount...I'm waiting though.
Did you replace spare and did it fit in factory place underneath? The grapplers in this size are now available in my area so I am ordering today or tomorrow.
REE
