Ten miles per month with part time 4WD
Just where are owners find a way to do this without going off road? Unless I read the manual wrong this is different than my 2001. They want ten miles per month but also say it only to use it on dirt, ice etc.... Any thoughts on how to do this in a city?
no need to run it in 4wd 10 miles. just put it in 4wd when stopped go forward and reverse several feet , a few times , your done .
the engagement requires some exercise that's about it .
if you are from austin area where the rain and hail falls on the road a lot you can run it a short distance on those flooded roads a block or two.
no need for 10 miles .
I'm usually on at least gravel once a month and switch to 4wd then, but if not I'll use it on pavement on straighter stretches during rainy days, or dry days on straight stretches of road.
10 miles
Just pop it into 4wd on a fairly straight highway and run for 10 miles. No problem except a miniscule extra tire wear. My '69 Land Rover was always in 4wd and the front tires took a beating. When I bought the new '75 LR I had the dealer put an adjustable hub on the front wheels so I could disconnect and run in 2wd until I needed 4w. No problemo! - Cheers Ted
This comes up from time to time.
First off. Absolutely no big deal if you forget..... It's a very rough rule, but not a bad idea to slip it into 4h once a month.
You want to exercise the various actuators and keep the chain lubed a bit.
There is 0 concern with putting your truck in 4wd on dry pavement. This is a total myth that you can bust a transfer case this way.
Use this rule of thumb when putting a part time system in 4wd on dry pavement. If the corner/turn cannot be taken at ~30mph shift back into 2H to make the turn. (basically avoid it in parking lots and sharp right/left hand turns from stop signs or lights. Besides that... It's 100% fine to drive around in 4wd on a part time system.
The truck sees way more drive train binding and stress in actual offroad rock crawling conditions in 4l...
I read this in the manual as well. Is it the same for the Limited since it has AWD? Should I jump it into 4H from time to time anyway?
Yes, and even 4low occasionally for all of the same reasons as above. Even though it is Full-Time AWD you still want to work the actuators and center differential the same as the other models (4Hi and 4L for you are the same as on the other models).
You're in Austin, Tx. Do you have any idea how many dirt roads there are in that part of the world? Take a side trip every 4 to 6 weeks and get some dust on it. :suspicious:
I don't do it. Never have, I'm on my 3rd 4runner with over 475,000+ miles combined between the 3 of them and never had an issue.
The 1st had about 210K miles on when I traded it in on my 3rd Gen which currently has 180k and still going just fine. The 5th gen has about 88K.......
They all got off road about two weeks a year in hunting season and maybe a time or 2 camping/hiking etc. but never 10 miles a month.
The oil film on metal starts to break down over time. Supposedly it takes about a month to fully break down inside a protected enclosure. But it's a sealed system, so it isn't like it starts rusting immediately. My wife is the primary driver of our 4Runner, and it sometimes goes months without 4WD (I honestly don't think she knows how to manually shift it). I try to run a few miles every now and then, and I do get to take her to play in the mud a few times a year, but rarely if ever do I get 10 miles/month.
The other issue is to keep the front diff locking actuator from getting stuck. Use-it-or-lose-it.
As for running on dry pavement, it's highly unlikely you'll break anything mechanical. Possible, usually because of some other undiagnosed problem, but unlikely. Your wheels will slip first. It does cause extra wear on joints and rubber, though.
The real issue is the fact that steering and handling are affected. No real danger driving slow in a subdivision or parking lot, or fast through straightaways or gentle curves on the highway. The danger comes if you're one of those people who drive a 4WD SUV like a sports car and try to take sharp curves as fast as you can. You go into the curve too fast, your tires start binding and slipping, and you hit the ditch (or a tree, or another car...).
I'm on my 3rd T4R.
When I have not been off road for about a month, which isn't often, I run in 4H on straight roads where the speed limit is 45 mph or less and go about 10 to 15 miles. Never worry about a gentle lane change or gentle curve. If a sharper turn is necessary, I just shift back to 2H, make the turn, then return to 4H.
After that I go to an abandoned Big KMart parking lot that is about a city block long. There I exercise 4H in reverse and 4LO in forward and reverse, back and forth in the lot. No turns, just forward and reverse in straight line.
This gets everything that moves worked out at least a bit.
Is it all really necessary. Who knows, but it has worked for me.
I usually engage mine for about 1 or 2 miles once or twice a week to give the 4wd a work out. As to the need to do this my Toyota salesman bought a late model 4th gen that had never been put in 4wd. He said that he had to replace the front actuators. Also I will work the rear locker occasionally by sitting in the driveway and putting it in low and engaging the locker and moving a short distance backward and forward.
I have to wonder why some people buy a 4runner much less a 4x4 4runner
Probably for the same reason that a few weeks back I noticed the ridiculously lifted Chevy pickup behind me on massive mud tires. He was lifted so much I could clearly see the entire front suspension in my mirror. It was a 2WD.
I'd say that the majority of 4Runner buyers (and 100% of the 2Runner buyers) would be better served with a Highlander or Sienna. But the 4Runner "looks" better. And they might someday drive through a puddle or snow flurry, so they get the 4x4 or TRDP for the "resale value". A co-worker was looking at buying one a while back and asked me about mine. I asked about his usage and needs, and he clearly would have been better off with a Highlander. But the 4Runner looked better.
Edit: Another example. We're looking at selling our older Pathfinder and getting another vehicle. She bought it before we got married... I hate the **** thing, but I drive it because I have the longer commute and it has 135k miles already. I want to get either 1) a small used high-MPG commuter car for me, or 2) a slightly larger people-and-dog mover for the family (i.e., a mini-van). She's insisting we need a big beefy lifted pickup because she thinks they look cool and she wants to sit up high (she's 5'-2"). Or maybe a Suburban. All for looks. We live in a city, and I park downtown in a parking garage. I used to drive an extended cab Silverado so I know what it's like to drive and park such a beast downtown. If I have any choice I will never own such a long and cumbersome vehicle again until I retire to my family land in rural Mississippi.
I have owned my '16 Trail for 3 weeks so I will preface this post saying I have not read my manual cover to cover. On my Gen4 SR5 I would run Hi4 all winter (I live in Minneapolis) and on the heavy snow days I'd lock the center diff which also turned off TSC. Steering on tight corner was lumpy but I expected this. Have said this when I have shifted my Trail into Hi4 it has the same tight lumpy 4x4 feel on tight turns, what is the difference between my Gen4 Hi4 and Gen5 Hi4.
You no longer have a center dif, (only the 5th gen Limited does) so by moving the 5th gen into 4H its equal to your center diff already being locked on the 4th gen. Living in Minneapolis as well j,ust leave it in 2wd unless there is snow/slush on the roads and then pull that beautiful 4x4 lever
If you are around the Edina/North Bloomington area much and see me - Wave.......the soccer moms and old businessman don't notice or care :/
Thanks Charles and I will.
I'm considering either a 2018 SR5 or a 2018 TRD Off Road. This will be my first 4wd vehicle, so I want to make sure I understand this preventitve maintenance.
For the SR5, I should occasionally run in both 4Hi and 4Lo, and I should also run in both Drive and Reverse. Is that correct?
Now, If I go with the TRD Off Road, I should do the same, but also add running with the rear locked to the list. Do I need to worry about exercising anything else (Multi-Terrain modes, Crawl modes, etc)?
Jhunt
