tensioner ilder pulley question
yella
in the middle of my TVB job and using Tim's video as a reference. When installing the tensioner idler pulley, Tim installs a washer behind the pulley. My truck did not have this washer on the old idler, and a new one was not included. Anyone know what the thickness of the washer is>?
Just looked at the FSM, and it mentions a "plate washer" as part of the installation but on the diagram it has no mention of it. Is it attached to your idler pulley?
Last time I did water pump I cannot remember if there was a washer there or not.
Yes there is supposed to be a washer there. I lost that washer when I was doing the TB/WP job. I ended up using a grade 8 washer that was about the same thickness.
I have a donor engine I'm swapping in my truck apart right now and can measure the washer you are talking about later today. I have it apart right now and that washer is sitting on my bench.
Also, read this.
TOYOTA P/N 90201-10098
Perfect thanks!
I found a washer in my parts bin that looks to be a similar size ( diameter ). I put it in behind the pulley bolt and put everything together; it looks like the arm for the tensioner is sitting in the middle now.
I will measure the one I have when I get home, but I think it will work. Thanks again
Just did mine yesterday and if your not careful taking the old pulley out the washer will fall straight down. It's a pretty thick washer, maybe 1/16 thick.
Here you go, this is the Toyota washer specs.
Sent from my SM-N950U using Tapatalk
D'Angelo
