MTD
The whole point of a supercharger over a turbo is instant power.
Agreed.
With no fuel mods (yet) once I touch the throttle it responds and quickly. Autos are just the same, and if you hit the ECT Power button it's even quicker.
Yes, my statement was more focused on the fact that there might be something up with his trans. ie short shifting, or dwelling...
Also, can I just say this: why are you looking for major power gains at 1-2 PSI? If you need more power or more speed, just press on the pedal more! You've already got the 7th injector, just use throttle when you need it. You will never get instant power at 1-2 PSI on any vehicle, no one builds their engine that way. That's why the engine is designed to have an open loop, it throws sensor readings out the window to ignore emissions and just goes for raw power. That's where you should be tuning, not in closed loop.
Okay... so we are going to tune so the vehicle only runs right at wide open and that's it? NO! This is completely and utterly wrong and it's the crap information that these forums have been feeding you guys along with the "apparent" monopoly URD has on this market with their sub par products! You tune to make the car run right first ie part throttle boost then work your way to WOT,not this 'lets make all the power on the top end BS'! And BTW in open loop it is still using sensors it just switches the ones it's using (O2 to MAF). The main issue is you are still destroying your motor even if you have the 7th but you boost it lean at part throttle. Contrary to popular belief WOT is not the only issue with our setups...
