>>The Best H11 / H8 / H16 LED fog light bulb - PERIOD
XenonDepot
BRAND NEW by Philips Automotive Lighting
LED fog light bulbs have always been nice cosmetic upgrades to better match your fog lights to your headlights... Until Now!
Philips has engineered these LED bulbs to replicate your stock beam pattern meaning that these bulbs will be both cosmetic AND functional LED upgrade bulbs Each bulb is rated at approximately 1200 functional lumens - the light goes where it needs to go.
These 10W bulbs don't require any moving parts such as fans to cool them down, and will provide you with almost double the amount of light that your stock H16 fog light bulb does (with a nice 6000k colour temperature to boot!).
Philips H11 / H8 / H16 LED bulbs are plug+play, and will plug into your OEM headlight harness with proper water-tight connections - a simple bulb replacement.
This is it guys... If you've been on the fence about upgrading your lights then look no further:
H11 Philips LED bulb | H16 Philips LED bulb | H8 Philips LED Fog bulb
[MENTION=12905]XenonDepot[/MENTION]
Maybe it's me, but does your bar chart indicate that these new bulbs are only a 5% lighting improvement over our stock H-11's?
Hi,
That is correct when compared to an H11 bulb. This would be a simple and functional way to enhance your H11 Led fog lights.
However, the 2014 4runner uses an H16 bulb for the fog lights, so this bulb will literally double the light output compared to the stock bulb.
Steve
Hi,
Steve
According to your website, all 5th Gens use H-11.
H8, H11, and H16 bulbs all connect into a PGJ19-2 IEC base - so we group these bulbs into an "h11 bulb family."
Steve
Phillips
While the Phillips LED looks like the Unicorn...for $179 for two, when in reality we need four, they can pretty much keep that.
I can think of about ten other mods to spend that money on, IMO.:roadkill:
Anything in the horizon for those of us that want/need an amber fog lights that don't require a retrofit or film?
Hi,
The Philips H11 LED bulb is definitely the unicorn. It provides awesome color, and a functional beam pattern for fog light applications.
They are not the right H11 LED bulb for the headlights though... If you're looking for something that is a little more cost effective, checkout the XenonDepot H11 LED headlight bulb. You can install these bulbs in both the fog lights and headlights. For a limited time, save 20% off when buying both....
Steve
