The everyday driver lift
osideplayer
I have a stock 2016 trail premium w/ KDSS and I’ve been looking at getting a lift. Albeit I am looking for a specific lift.
I need 2 inches in the front and 1 inch in the rear. So how do I get this exactly?
I don’t want spacers, I know that is the easy way to do it.
Anyone do this lift exactly, what did you use? Part numbers?
2,500 hundred is the budget for parts
Lift kit that uses coils that give you a 2 front and 1 rear lift. Dobinsons and bilstein 5100s is a good place to start.
I have 5100’s on my 3rd gen and the ride is super hoppy. Not looking to go that route. Anything a bit higher quality or more dampening?
Hmm seeing that your in socal...you could ask Kai for a ride in his dobinsons equipped car to see if you like the ride haha
When I was looking around for suspension bits, I test drove a friends rig with the 6112/5160s and found them a bit to harsh/stiff. I find the Dobinsons kit I went with to be more comfortable.
I am in Mission Viejo if you want to check out my ride with King. Got 2.5” in front and 1.2” (I think) in the rear with T13 springs. It is a little harsh with LT E tires.
Yea, I actually would want to check it. I work in Mission Viejo. How is the ride? any pics :)
5100's at 1.75 and a daystar rubber in the rear........it will ride mellow and that's as cheap and simple as it can be.
Can I adjust Kings to 2 in the front and 1 in the rear?
My budget is 2500 for parts
That'll take the entire budget. you can adjust the fronts to 2". the rear will require a coil spring or a spacer to get 1" of lift. But nothing rides like a king.
eibach kit is what 1k? and that's for everything you need. Leftover for wheels.
So I think I am going to go with Kings in the front and 5160s in the rear
$2,500 budget for parts isn't small. Will a King OEM set get the job done or are these not adjustable in that range?
bobdjr41
