Mixed driving on my well maintained v6.......
wow man...the computer on my V8 usually reads 17.8-18.6
EDIT: just thought i should point out, i reset it on every fill up. and the numbers i gave above are where it usually falls when i fill up again
my mpgs hang right around 18.5 to 19.5. I do alot of freeway commuting but also get the same mileage if i go on a roadtrip through the mountains. Im fairly hsrd on the skinney pedal too.
OP, I feel for you. I'm also on the same boat, tried everything you did & then some. Any updates on your issue?
Pic of my trip computer after a fill up ( no top off, never ).
zstampe: winter gas or not I've had the same problem for about a year to no avail so that really crosses out the winter gas mixture as an issue. I would however really like to try ethanol free gas just to experiment but nothing in my area. I'm running 265/70s which may or may not affect my MPGs, mechanic says yes it def would; I guess but I swear I had the MPG problem before I switched for bigger tires ( was just slightly bigger!!)
I also have a thread on this (to which you have replied). Someone suggested topping the tank off which makes sense since the autoshut off varies from pump to pump so topping it off would be a control factor. Also need to buy a second set of tires (stock size) to totally bring everything back to stock (CAI has been off for a while).
*sigh* what happened to the good old days of seeing 380-410 on the range comp? My driving habits and everything else (auto shut off at the pump) were the same. Why such a drastic difference now? Ethanol conspiracy? I'd really like to see if there's a correlation between our MPG problems & when my local area stations switched over to using ethanol. If only I could get that data.
Yeah try the ethanol free stuff, I don't remember if you seafoamed the truck or not?
Seafoamed, check! (unless I put it through the wrong vacuum hose)
Ethanol free in tri state area NYC is probably impossible... just gonna learn to live with it I guess
I have the same issue, well maintained 2006 sr5 V6 with about 64,000 miles. the mods I have are 265/70/17 c load duratracs, all pro spacers, daystar budget lift, HFC delete. I USE to get 19-22 mpg when i was bone stock(with the hfc delete), after all these upgrades I see 15-16 mgs on my trip comp regularly. Take into consideration, bigger tires affect the speedo, but come on.. almost a year later and 4 mpgs less all the time. I believe its an issue with all the crap they are doing to the tri state area gas period!!!!
Damn fellas, sub 300 mile range?! Was getting 400 before lift and 33's, now I get 335 a tank! Gotta love the destinations!
