The oil leak is getting worse in my base manual 4 cylinder 2WD 4Runner - I had to put two quarts in today.
I had bought cans of engine degreaser and sprayed it all over the bottom and top but I still I couldn't find where the oil is coming out from once the 4runner was driven a bit.
I'm spraying again this week to try again.
I think this is the final list of key culprits to suspect in this order:
0. Oil drain plug, oil filter gasket
1. Oil filter extension housing o-ring
2. Oil pan gasket
3. Rear main seal
4. Front crank seal
5. Valve cover gasket (and front & rear camshaft covers & housing plug to the rear of the camshafts)
I think the location of all but the rear main seal and front crank seal are self explanatory. I'll look up to see if I can find a diagram or picture of those two seals.
EDIT: Looking for a picture of the front and rear seals, I find these threads:
Rear Main Seal or Oil Pan Gasket Leak (no pictures)
a. 6 hours labor for each seal
b. Best to use oem seal
Rear Main Seal Question (no pictures)
a. No additional groove or sleeve for the rear main seal (RMS)
b. Don't drive the seal in all the way
c. Use OEM seal only
d. Good mechanic can do the job in 5-6 hours
new rear main seal still leaks (no pictures)
a. Fel Pro seal was sealed with RTV but still leaks (grooved crank?)
b. OP said he may sleeve the crank
c. OP said OEM seal worked, after greasing
d. ChildrenOfBodom said the same thing happened to him
e. Unfortunately for the RMS, you remove motor or drop transmission
f. To drop transmission, FSM says remove sway bar & exhaust but that's optional
g. 11 hour job, need transmission jack
2000 4Runner - Rear Main Seal Leak? *Help!* (no pictures)
a. A large leak will affect manifold vacuum
write up for rear main seal (no pictures)
a. OP is looking for a RMS writeup
b. Remove transmission & flywheel, R&R the seal, perhaps sleeve the crank
c. References
3.4L Oil Leaks (150k) - Page 2 - YotaTech Forums
Rear main seal replacement inquiry (no pictures)
a. $1,300 job at Toyota to replace RMS
Pretty sure I have a leaky Rear Main Seal
a. disconnect driveshaft, undo bell housing bolts and linkages, drop tranny crossmember.
b. Chadman refers to:
CYi5's '99 4Runner Buildup - Page 15 - Expedition Portal Forum but that's for the 4WD
rear main seal leaking questions ? (no pictures)
a. Nobody replied
changing the rear main seal... (no pictures)
a. Rather slit my wrists before doing that job again
leaky rear main seal?
a. Implies that the use of Mobil1 oil cleaned out the sludge around the rear main seal
rear main seals (no pictures)
a. $1,100 dealer repair for RMS
Rear Main Seal (no pictures)
a. Pour oil additive seal leak into the engine oil?
b. 8 hours to drop the transmission
YotaTech 3.4L Oil Leaks (150k)
a. VCG is a PITA because you have to remove the intake
b. Make sure you seal the camshaft covers (use a mirror for the rear CSC)
c. Use Toyota black RTV (not Advance Auto Parts black RTV)
d. When doing the valve cover gaskets replace the gromet for the PCV
e. Use Felpro VCG
f. A major leaking spot on the 3.4's is the housing plug to the rear of the camshaft. It is covered by the rear plate
g. Buy FIPG from the dealer (whatever that is)
h. Don't forget the cam cover plugs
i. Toyota FIPG and Grey RTV make for a great and lasting seal
j. Replace spark plug grommets while you're there
Is This The Rear Main Oil Seal?
a. Pressure wash first to find the leak
b.Use blacklight dye to pinpoint the leak
oil leak problem (no pictures)
a. There are ultraviolet leak detectors you can buy
