The new OEM air filter...
Dynamo
I believe it's been discussed before but apparently our OEM air filter, p/n 17801-38051, has been superseded. That's what the dealer that I order all of my parts through told me when I ordered one. The new p/n is 17801-YZZ13 and that's what I was given. The pleated portion is about half the depth as the old filter and the foam pre-filter is gone.
I'm sure it will work just fine but I don't like. :mmph:
Pic for reference:
Update - I got one of the Denso filters, p/n 143-3025. Dimension wise it is the same as the OEM filter. It includes a foam pre-filter that is very slightly thinner than the one on the OEM filter. It also feels a little softer and not as coarse.
The Denso filter looked like it didn't have as many filter pleats so I counted them on all 3 filters.
OEM - 109 pleats
New OEM - 131 pleats
Denso - 98 pleats
So the new OEM filter is not as thick but it has quite a few more pleats but my guess is it still doesn't equal the same surface area as the original OEM filter. I doubt it even has the same surface area as the Denso filter. Again, I'm sure it will work fine. Me personally, if I can't get my hands on one of the original OEM filters then I will most likely use the Denso filter.
My guess is the new one is better. The new one seems to have the profile of the TRD filter. I wonder if that's why the 4Runner TRD filter was discontinued? Part redundancy?
If I had to guess I'd say it was due to supply chain issues. When I ordered the original p/n the dealer told me about the new superseded part and that it was on a 3-6 week national back order. Less material so they can make more to stretch the supply out. My theory anyway but who knows.
They likely superseded the part number because too many people were *****ing about how they got half a filter in the normal filter box.
I remember when we started getting these "new" EAFs and I was like, "uh... big box for tiny filter."
My guess is supply chain issues, we've seen a lot of the engine air filters and cabin air filters get "superseded" with slightly thinner versions...
Same reason a Hershey bar is half the size it used to be for the same price. Another way for all $ to move to the top 1%.
I like the "pre-filter" I took mine off the old one, rinsed it off and hot-glued it to the new filter. Keeps the big things from getting into the pleats. But, as long as you change your filter when it gets old and dirty, you should be fine either way. I'm on filter #3 with 105k after 12 years. Of course the conditions you drive in makes a big difference.
FYI. i bought a wix filter at the local auto parts store. It was damn near identical to the OEM filter.
Same depth, same pre filter..
I believe it's been discussed before but apparently our OEM air filter, p/n 17801-38051, has been superseded. That's what the dealer that I order all of my parts through told me when I ordered one. The new p/n is 17801-YZZ13 and that's what I was given. The pleated portion is about half the depth as the old filter and the mesh pre-filter is gone.
Pic for reference:
Where are you located? I had a dealership in Georgia swear these were superceded and could not be ordered but then called a dealership in California and they shipped them out same day. Could it be a TMS/SET/GST difference?
It's not. Here's the thing. Toyota has a budget line of parts, and often dealers push these because there is a higher profit margin.
Anything with the YZZ in the name is a budget lower quality item.
They plain sold this person a budget item and probably charged full price for it too. $$ in the dealers pocket.
The dealer I use is in Austin, TX.
It was $15.38. I was told the original p/n is no longer available.
Also, what about the OEM oil filters? I have multiple Toyotas in my household each using different different oil filters but they are all YZZ part numbers. As far as I know other than the TRD filter there is no other oil filter available.
Everything YZZ is a budget/value item, lower quality. You can just search for "toyota yzz" and find plenty of information on it.
As far as the Toyota supply chain right now I have no idea, I just bought the normal filter a few weeks ago along with some TRD oil filters from my local dealer. Looking at toyota parts online right now, it shows the normal and the budget filter as not available
Also fwiw I have also used amsoil and royal purple oil filters and cannot tell them apart from the TRD oil filter side by side other than the TRD stamp, they are basically identical.
Interesting, thanks for the info. I just watched a youtube video from The Car Care Nut where discusses the part numbers. He indicated for the YZZ parts that in most cases the original part numbers are hard to get.
If by budget line you mean "sourced in the US." Some time back in the 90's Toyota started sourcing parts "locally" i.e. having them made in the US or at least North America. Most of the YZZ stuff just indicates that it was likely made by some sub-contractor for Toyota in NA vs. Importing the part from a factory in Japan.
I think you guys are mixing up that for a while Toyota tried to start a budget line of a things like Brake pads and such. Those brake pads had AZ numbers that were similar to the "good" factory brake pads, but the budget had a specific AZ#### series I think. I don't remember who made the pads, but they were notorious for glazing, squeaking, and pulsation for anyone doing a moderate amount of stop and go or heavy braking. I think they eventually discontinued those pads a couple years ago (after basically forcing dealers to order that stock) and then just quietly superceded some part numbers and issued a bulletin letting Parts and Service know that we would have to sell shim kits along with the old budget pads when doing a brake service (because the budget ones came with one-piece brake shims like a lot of crappier aftermarket pads).
Long story short, most YZZ part numbers are for service parts sourced locally through Toyota's supply chain. i.e. the old -YZZ20 suffix was for the more common standard Cabin Air Filters that come from the factory in most newer Toyotas. That was superceded now by -YZZ82, which seems to me to have similar filter media, but less pleat density. But the "premium" Charcoal Cabin Air Filters used in some Lexus and Toyota vehicles, or as an upgrade from the -YZZ20 ends with -YZZ10 (I don't remember if they superceded these as well, we don't sell a ton of them and I use a different carbon one in my 4Runner). Long story short, Toyota's part numbering system has gotten far more complicated than it originally intended to be because of their growth. I think they still have some oddball overlapping part numbers depending on country of origin, i.e. one part number in Japan for say an axle seal, might actually be a different part in the US. I think they fixed most of that in the 90's early 2000's? It's been a while since I looked into the parts side of things, I don't work in parts so it was more for fun/curiosity.
But I do think a lot of these superceded parts are because of material sourcing issues and so they're trying to stretch the supplies they have as much as possible. Now, whether or not they'll go back to the original "plumper" stuff when things smooth out... that will be the real question...
You might be right about the material sourcing issues. I found the thread below and it looks like the YZZ air filter has even changed. At one point it was essentially like the original air filter minus the foam pre-filter. Now it's half as thick.
Engine Air Filter fitment 17801-38051 vs 143-3025 - Page 2 - ClubLexus - Lexus Forum Discussion
Yeah, they used to come in the original box and so you'd be like, "what the hell is this a bag of chips?! It's mostly air!" and then after like a few weeks we got the "new" part number and smaller box. :pound:
AndiGarage
