The Turbo Rock Lobster
Oh hello there
b5a0a790.jpg~original
Well thanks to Awilson013, the supercharger setup is one step closer to being complete!
aa083bee.jpg~original
My original plan was to go for the 7th injector setup from URD but i think now i may go a different route. The new plan is:
Supra injectors,
Larger MAF (already sitting on my shelf)
URD MAF calibrator
Stay tuned.
Looks like you're on your way!
On a side note:
Would the Supra Injectors work well on a Naturally Aspirated 3.4l??
Thanks! Its still a long road until its done.
yes and no, yes they pump more gas, no because they dont fit right in, because the the tips are a tad too big.
They do fit in but you need a lot more than just the injectors to make them work.
There are a couple reasons why you can't just swap them in.
First off, The stock ECU doesn't know how big your injectors are. All it does is control the injector pulse which is length of time that the injectors are open. When you put in a larger injector, It still thinks you have the stock size injector so it keeps the pulse the same. This means that is it dumping in more fuel all the time. The problem with that is if you are not in boost, It is going to be putting in more fuel than needed and will run rich. Because of this, you need a way to change the injector pulse from what the ECU is telling them. That is where the MAF calibrator comes in.
Second, there is really no reason to put larger injectors in a naturally aspirated 3.4. The stock injectors can handle 7+psi of boost so they are more then enough for no boost.
What might be beneficial is to install a MAF calibrator to richen the mixture which should give you a bump in power. URD claims that they got 15hp out of a stock Camry with their MAF calibrator.
Haha, well your coils were out and the new superflex were supposed to come out soon. Also I confirmed my guess by going to your first page and seeing you added the superflex to your mod list. I'm interested to see how they are. I'm happy with my height, but you never know for the future.
REE
