Thinking of cutting those factory wires... "you may not have to!"
rigtec
Greetings,
...and happy Trails ('TE') to all! I was just speaking with another forum member regarding an audio install that he's about to do and that reminded me to pass this convenient little gem on to you! It just occurred to me that so many of you are performing your own electrical accessory mods and add-ons, that I should be passing some of my own electrical tricks, short-cuts and tools over to you whenever they come to mind! 'That said'... here's a nifty lil' gadget that I think some of you'll find helpful!
Now I really don't like cutting my truck's 'factory electrical system wiring' AT ALL! But, there are times when I've had to, to complete a repair of some sort or an aftermarket equipment install! This will help to eliminate those infrequent times when you have to:
They're made by POSI-PRODUCTS https://www.amazon.com/gp/product/B004D0C18C/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=A2Q32NH2TXUFG5
This would've been great to have had when I was installing some new 'Factory style push-button switches in my dash to operate the aftermarket fog-lights and LEDs that I installed a couple years ago! The way they work is... instead of cutting a Courtesy Interior Lighting circuit wire to feed the aftermarket accessory equipment e.g., dashboard switch "Night-glow" back light, relay circuit triggering...etc, all you do is: place the wire that you need service from in the groove and push your new accessory wire into the barrel. Then 'gently' thumb tighten the barrel head... That's it! This leaves no damage to those factory wires. And... if you ever need to take the truck in for service, you can very easily remove (Temporarily) the new accessory from the factory wiring; so ('if you're really careful'...) "no more compromising (VOID) that factory warranty!"
Be sure to see the featured instructional video on the "Crutchfield" pg (scroll to the bottom)! Posi-Products™ Wire Connectors 6 tap connectors for 16- to 18-gauge wire — tap into wire without cutting or stripping at Crutchfield.com
Cheers :usa2:
I've used these before on a MOD when I had my FJ.
They were indeed easy to use with positive results!
Recommend
I've seen 'em. I personally think they're a fancier scotch lock and/or butt connector. They all have their place and I can appreciate the ease of use but nothing beats soldering properly.
I realize you're posting for those who don't quite have the skill with electronics and for those who are concerned with removal of aftermarket pieces. But for me personally, they belong in the round receptacle. Nice find for those who could use it though.
And this probably could be more useful in the general section.
i've used them in the past as well and if you don't want/don't know how to do a proper cut/solder/re-shrinktube they do the job.
Greg, gonna move this thread to a place where all generations will find it. I'm sure it will be useful for a lot of owners.
I used a version for my ranger head unit upgrade...worked great but can be pricey. They have waterproof versions too should you need them.
The telco industry uses all sorts of different connectors, these are one of them. I call them job security, because if it weren't for these things failing all the time I wouldn't have anything to do at night.
Thanks for sharing, rigtec. I was not aware of this at all, and it looks like a great option for adding some accessories. I'm working on a project to add some strategically-placed led lights to help with finding buttons and switches at night and this will come in handy.
maybe i should consider this, ill keep my t taps and male terminals since i bought them in bulk for the cheap.
I would have gone broke using these things in my swap. I had more then 150 connections.
i would have respected you A LOT less if you did. You probably will be chasing issues right now because of poor connectons.
these things all have its place in the world. they are NOT used in my day to day installs.
lets drop the dash in any one of these cars and see these taps. you would be beyond pissed.
Dat ass
Hi riceandpho,
I've got a stockroom full of wiring accessories which will 'ALWAYS' be useful, I just want to avoid butchering the stock wiring whenever possible!
Rdgs!
thats the cheap ass, only $232k and its a 570LT, got a 675LT that listed at $399 and owner paid a extra $150k to get one of the 3 for this area a few days earlier.
I paid an extra $14.99 to have my wife's flowers delivered before lunch on Friday. That's the same thing right?
youngrk
