Those with rear air...
Mike07SE
Can any of you guys with the air suspension due me a favor and take some pics of the factory air compressor and how it is mounted as well? Looking at going with onboard air and trying to come up with some mounting ideas.
All pictures are taken from the driver's side and the rear of the truck.
The compressor sits right behind the wheel. It is behind that cover which I didn't have time to mess with to get it off. You can see one of the mounts.
A bit closer view.
This tank is a bit farther forward from the compressor. You can see one incoming line that comes from the compressor and 2 outgoing lines that goes to each side.
Hope this helps. Be sure to post some pics of your work when your done - I'd love to see it.
Probably going to go with a Viair compressor that's rated around 200psi/100% duty and use a 2.5 gallon tank.
Edit: I clicked on your lift for air lift. I'm not doing an air suspension, just on board air.
Oh I see. Has anyone tried either of the two air suspension systems that I mentioned? I was thinking about getting a hitch cargo carrier for hunting and with the added weight wanted something to level the truck out.
BillM777
