Throw bearing chatter: high mileage
DED&DED
Sunday night the throw bearing began to chatter soundly enough that even I could hear it. The local dealer o not seem interested. The garage I use for oil changes and general service recommended an independent transmission shop.
They use after market clutch assemblies. I prefer Toyota parts. Are there any after market clutches that are good--or which ones should I avoid?
This a '99, SR5, and I am the original owner--280,000 miles.
I welcome your advice and suggestions---Thank you
This is what I installed two years ago. AISIN is the maker of the OEM clutch. This kit has been slightly redesigned but I have complete confidence in the AISIN parts for which they were original supplier.Toyota owns a big piece of AISIN. I installed it myself and it shifts as smooth as butter. I highly recommend you do your shift seat bushings while you are at it. Makes a world of difference. (Marlin crawler sells polyurethane ones.)
http://www.amazon.com/gp/product/B00340FETK?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
If you want to spend s few more $$, there are many good reports on this heavy duty clutch sold by Marlin Crawler:
https://www.marlincrawler.com/clutch/heavy-duty/clutch-tacoma/1995-04-6cyl-1200-lb-clutch-kit
Thank you---I am out of the DIY demographic. The shop would have used a Luke--but agreed to used Toyota parts. Next up on the to-do list is the timing belt. Then I'll be good for another 100K.
