Thumb throttle
I haven't done it, but I think it would be worth a shot--when I had mine out crawling, I kept inadvertently goosing the throttle from bouncing around. Does it allow you to still use the regular pedal for normal driving?
I've seen a couple around here - they're basically a section of bicycle cable, tied to the throttle and routed through the firewall to a bicycle shift lever on the column (or wherever). Pull the shift lever, get throttle. Very handy if you've got three pedals and two feet.
