Ticking Sound when driving
longobongo
Whenever I drive close to walls and have my windows down, I can hear a ticking sound on both driver/passenger side... It sounds like its coming from both wheel housings. I am wondering if its just rocks stuck in the tire tread and hitting the pavement or maybe a exhaust manifold leak?
Could it be something with my tires? I had new tires installed about 3 months ago... Havent really noticed the ticking until about a month ago... Everything seems to run fine tho.
Does the ticking speed up and slow down along with vehicle speed? Have you inspected the treads for pebbles, or nails/screws or other foreign objects stuck in the tread? This is usually the case. I would check that out first before digging further since it's the most obvious thing to check.
Or, it's a bomb.
Check your calipers & see if you have 2 retaining clips for pads , I had heard same thing & saw a post about this . Easy fix if you don't have go to parts store & buy 2 more !
Or, it's a bomb.
It seems speed up along with speed. Me and my 4runner are in Africa, so there are rocks and pebbles everywhere. So I wouldnt doubt if I have a couple of pebbles in the treads... hopefully no nails or screws.. But I will look for that.
The retaining clips would make the ticking noise?
charlesz
