Time crunch! Gotta find a brake booster and install in less than ten days!
Aloha guys so I'm OAM to fix my truck. It's a 94 T4R 4x4 4cyl manual. I can tell you a lot about it. But, what I can't figure out, is if it's ABS or Not!??? I need a way to find out so I can swap out the brake booster that failed on it. I also need to find out ASAP because I have to ship the truck on the 27th and the brakes need to work to put it on the boat safely. Yes it does still brake, but if some idiot doesn't press them hard enough then we got problems! I also don't want to put anyone at risk either.
SO I've been scouring the internet trying to decipher if my truck has ABS. There is no light when you turn on the key without starting that says abs. There is nowhere on the truck inside or out that says abs. There doesn't appear to be wiring to the rear brakes and I can't really see the front to tell yet (it's getting dark here)
How can I tell without a doubt which brake booster to get? I pretty much gotta order this thing tonight because there's none on island (of course!) and pray/pay that it can get here in a couple days and I can swap it out ;)
The ABS systems on these vehicles were on the rear only and ran off the power steering system. Easy way to tell if you have it is to look at the rear axle and see if there is a sensor in the top of the rear differential. I've only ever seen it on a few 4runners in the junkyards and not on any pickups.
PRWhite
