Rock_Rat
Senior Member
Yea, he said the same thing about the battery terminals :tongue1:
As much as I'm a die hard Ducks fan, I'd call the Husky tat a fair trade LOL.
Yes, you have to be very careful if you remove them like this, but it worked well. You will want some kind of tool to break the surface of the seal first, so you can get the screws started. Once the seals were removed, we used 2000 grit sand paper to touch up the journals.
We'll see what happens Oct 8th...I'm, hopeful this year.
Guys, for my personal information, when using those big wood screws to remove the two cam seals, couldn't the large wood screw gouge the metal surface of the camshaft and cause a leaking seal at the next installation? It clearly appear to be outside the inner race of the seal.
Yea, not a huge fan of the screw method. I brought my seal removal tool with me and mentioned someone on here recommended using screws. We figured we would give it a try. Honestly, not a fan. The journal was ever so slightly scored and we spent some time on it with 2000 grit wet/dry paper until you couldn't feel anything with your eyes closed. I was 100% confident before installing the new seals. I think I'll stick to my seal removal tool the next time.
