timing belt/water pump replacement kit
AndreiR
Hello everybody!
I'm planning to replace a timing belt/water pump on my 99 4r*r SR5, 6 Cyl 3.4L. I found this kit online for $122.84
In a Fit Note (on the site) it says that it's for "DOHC, With Bypass Tube, For Models with Engine Oil Cooler." How to find out if it's what I have?
Also is this a good place to buy a kit, or there is a better place? Please recommend! :)
Thank you for your help!
AFAIK we don't have engine oil coolers in our gen? If we do I'm blind because I haven't seen the lines.
Looks like this should work for your truck. I'd go OEM but if you're on a strict budget and you're not worried about the brand (which they don't list) this will get you going.
Thank you all for your help! I see your point. Sure, makes sense to go with OEM parts.
Thanks again!!! :) :) :)
Search for AISIN TKT025. Aisin is the OEM manufacturer. About $175 from RockAuto. FYI, the 3.4 engine does have an oil cooler.
I have one in my '02. From what I was told in a different thread most, possibly all, 3rd gens have an oil cooler and need the water pump with the connector for it.
Like this one. Amazon.com: Aisin TKT-025 Engine Timing Belt Kit with Water Pump: Automotive
You could go to a dealer and ask the parts dept for the item number you need, based on your VIN, for the water pump. Or just pull the engine cover and look.
Well look at that! Thank you for the correction. IDK why I assumed it would be a cooler line.
I was just ordering this same kit from amazon, WallyWest, thanks! Done deal! Now it's waiting time ... :roll:
