Tire carrier
1992-4r said:
Is it possible to take a Ford Bronco spare tire rack off and mount it to my 1992 4runner?
Hmm, I've seen it done, couple of times over here.
The thing is tho' that the body isn't strong enough to hold it up, so you gotta put something inside to support it.
Maybe if you take a look inside the bronco and see how the support is there, just make it abit more stronger than that.
Personally, I'd rather replace the rear bumper and make it so I could have the tire rack bolted/welded on that.
But of course, I don't carry spares, and the few times I do (During "rescue" missions that need extra tire for the one bein' "rescued") I keep on the roof rack.
It's abit scary with the 44" up there tho' :D
But <38" should be okay on the roof.
Well I was debating on the roof rack and the rear tire mount. The roof rack would be easier to install but i was thinking that it would be hard to take it down in the case if I get a flat... but i really like the roof rack style.
Hmm, what size of tires do you have?
I had no problems gettin' the 35 and 38 off. Even easier if it's flat :P
The bronco rack is a feasable option tho'.
Abit harder to do, and not good for the rear end, might have to put tougher coils under because of the weight.
I've got 31s so it won't be that big of a deal, but I was leaning toward the roof rack anyway. What kind of rack should I get? I need something that won't blow my budget.
Unfortunatly I usually just make my own (can't afford buyin' expensive racks).
But I think there are some from Rhino and Thule, not sure if ARB has some... I'd do a google search for "roof racks" and you'll prolly find plenty. :)
FYI, I mixed my roof "rack" out of profile pipes and the roof bows (what's the english word over this? The chrome stuff on top of my rig) and used U-bolts from wire clamps (for really huge tow wires like in cranes) to fit it on.
Here's a pic of it.
attachment.php
More pics in my gallery thread ;):
http://www.toyota-4runner.org/showthread.php?s=&threadid=33313&perpage=15&pagenumber=1
1992-4r said:
If i get the roof rack do i need to get a tire mount 4 the basket?
I think there are some brackets available, but I'd just use straps to keep it down. I've used 4 of 'em to keep my 38 and 44 down and it has never failed.
Especially if you are tight on budget.
31x10.5 tire fits underneath the truck in the stock location. i've got one under there as well as a hitch.
BlackLabeL,
How were you able to get a tow hitch and a 31 inch tire? All of the tow hitches I've seen say they won't fit with a 31 inch under-mounted tire.
I'm trying to add a second spare (undermounted) and a tow hitch. Currently, it has one rear mounted spare and I bought a 90 4Runner for off-roading in Baja.
Thanks,
Joel
joelbra said:
BlackLabeL,
Thanks,
Joel
I'm not sure but would the fact that BlackLabeL's 4Runner is a 2-Door have anything to do with that? maybe there is more room in that area of the truck for a 31"
Just a thought...
Just a thought...
AFAIK, the Leaf spring suspension takes less space than the coils, because of the upper links, the frame piece that holds 'em is bigger than in the 1st gen, so that could be the reason, I'm not sure tho'.
I've seen 33s fitted under there with great pain and bashing, I can't remember where tho'.
(Definatly (Sp?) not in Iceland, as we usually don't carry spares. :P)
I'd think tho by cuttin' abit from the pieces that are between the frame's sides and re"making" them or putting pipes between instead 31s should fit there. Also you could just "redesign" the hitch holder, but I assume your not as crazy as I am, nor a very good welder. (assumin' if you were you'd have done this already... :P)
Well the reason i was wondering about that was because the spare tire mount under the truck is ceased up and rusted to pieces.
My 31" is under my 4Runner and I dont have a hitch but since I have a "Mystery Bumper" on the back of my 4Runner, not sure what its from but the hole in the bumper that you stick the rod with the hook through to crank down the spare tire doesnt match up with the link at all. The link is off to the drivers side but the hole in my "Mystery Bumper" only lets you stick the rod in straight, perpendicular to the bumper.
Anyways, because of this it is a pain in the butt to get the spare tire out (I dont like having it under there anyways) so I am going to get a roof basket installed and put it up there until I can afford to buy a bumper and tire swing from Big Country Customs. I havent done alot of research yet but I know I eventually want the custom bumper with a tire swing, where I'll get one; Im not sure yet.
Snowman904
