freeflight
Hi Gentlemen,
I need to replace the tires on my 04 V6 4Runner, everything stock. Stock tire size is 265/65/R17. Intended use is 80% street and highway, 15% desert driving in SoCal, 5% rocky trail in the mountain. I have narrowed it down to these tires
BFG AT KO, $233, LT265/65R17/E,120S, 30.7",3085@80 psi,15/32,51.2 lb
BFG AT KO2, $200,LT265/70R17/E,121/118S, 31.6",3,195@80 psi, 15/32", 52 lb
Goodyear Duratrac,$180-190,
P265/65/R17,112S,SL,500BB,51PSI,30.6",2469,16/32, 42 lb
LT265/70/R17, 112Q,C/E,50/80PSI, 31.7", 2470/3195,18/32, 44/50 lb
KO is older technology than KO2, but it has my stock size of 265/65/R17. If I go with KO2 LT265/70/R17, tire size will increase from 30.7" to 31.6". I also like Duratrac from what I read here, but 265/65/R17 is metric size. If I want LT tire, the next size is 265/70/R17. Same problem.
Would going from 30.7" to 31.6" cause problem for on road and moderate off road driving?
I like LT tire for its durability, but it is a few lb heavier and stiffer. Some sacrifice in ride quality is expected. Would you go for LT tires for my intended use?
Thanks,
Kevin
Thanks,
Kevin
