Tire pressure and rotation on my new 285/70/17
Fermn
Member
What would be the ideal tire pressure on my new set of tires ? The shop said 35 psi but I think that’s kind of low for the size of the tire.
Curious as to what everyone is running to daily drive their vehicles ?
Also, what’s the recommended way of rotating these tires ?
I rotate at oil change, around 7-8,000 miles. Spare is stock so it's 4 tire rotation.
I drive to work on Wed, home from work on Sun-Mon.
One way is 4 miles rough dirt roads (20 mph max) & 18 miles highway (65 mph).
Summer reaches +120°f, winter is teens & the roads are mud.
So summer I run 37psi, heats up to 40psi. Winter I run 30psi.
Toyo Open Country A/T 285's
Do you do regular rotation or cross rotating ?
Everyone is different, so this is just my opinion not a suggestion for what it's worth.
The vehicle, tire size, driving conditions are just parameters. What matters is your intent and preference. What I like or do with my equipment is not the same as anyone else. In the end do what makes sense for you and your situation. Keep it safe and make small changes and see what works for you.
i.e. don't fill your tires to some random pressure based on some random post, from some random dude on the internet and run the Baja 500.
The tire shop gave you the generic pressure that shouldn't cause you to crash too much. If you look inside your driver's door frame a sticker will show the manufacturer's recommendation for each tire. That's with the OEM tires on OEM wheels and again it's the "safe" bet.
Here are a couple of other resources.
How To Choose the Right Air Pressure For Your Tires - The Dirt by 4WP
https://www.tirerack.com/accessorie...hting&ef_id=Xl1IegAAAMuJF@De:20200621120504:s
Personally I run them a bit higher for everyday driving, but I live in the bay area with what they say are "paved" roads and consistent weather.
I know it all comes down to personal preference and situation but I just wanted to hear opinions.
Thanks for links
I'm stock size on Toya ATII. I run 2 psi over the sticker on the door panel. 30K and the tire wear pattern looks even. 265/70-17 load range C.
I air down to 20 for trails and 15 for deep sand.
You never stated what load rating they are. E Load, is going to be more than a SL or P rated tire. 32-35psi cold depending on preference and load would be what I run in a SL rated tire. 38-45psi is what I would run in an E load rated tire. Depending on load.
C load 285/70/17 KO2 and live in south Florida
