Tire Size Opinions
GregGimbert
How big & keep mud flps & run boards
2005 V8 SE, have a Cornfed 3/2 to install. Question is how big can I go on tires without having to remove mud flaps or running boards? Thanks for your input.
Greg
Re: How big & keep mud flps & run boards
Greg
Typically it will depend on the final tire size. Not all 33's are 33" They may be 32.5 or 33.5. Anyway, 33's should fit fine with the lift. The only thing to check is a 33 may not fit in the spare area depending on your hitch. Anything more than a 33 and you may need to start trimming.
Hey Greg!
Im pretty sure the running boards can stay regardless of tire size.....i mean unless your going HUGE.....
And yeah, if you wanna keep your mudflaps on too then maybe the same size tire ProMed used would be good, im sure it would be as its like the next size down from the tires that need minimal trimmings.
Good luck and gimme a holler man! I got lots of trails to hit!
Ray
MaximussK
