tires and wheels
afrazier15
ok people, it seems mechanics dont even know what to tell me. I want to run 15 inch wheels with 32 11.5 15 mud tires. I have a toytec suspension lift and currently run 285 75 16. Will i be able to fit the 32 11.5 15 on my 98 4 runner....WITHOUT doing any further installments. Thanks guys.
Did you come stock with 15" or 16"?
If 16", than no. You CAN NOT run a 15" rim because it will NOT clear the caliper.
right. well the vin number and inside door panel says it can take 15 inch and 16 inch and that it was factory 15. but when i got the 4 runner its had 16 inch yota wheels already equipped so im not sure and it has 6 lugs one of those being a wheel lock. ( if that matters)
check the spare. If the spare is a 15", then it came with 15" from the factory, unless someone was smart enough to change it to the 16" rim.
Go to a local scrap yard, see if you can get a 15" wheel from a 99 Tacoma, and see if doesn't hit the calipers.
2001ATL
