Tires Guide
Once this is complete, it's going to need a huge ass sticky complete with flashing lights and sirens. Thanks for taking the time to compile all of this info!
I need Info with body chop and info on 285/75/R17. 295/70/R17. 305/70/R17. and if any one as something bigger way in.
OK guys, I need the stock 4Runner BS and offset numbers for all three wheels. Also, do the '14TE wheels still have the same width as the '10-'13 TE wheels of 7.5"?
[MENTION=66316]1engineer[/MENTION] [MENTION=68981]jam23r1[/MENTION] This is a great idea Guys. Once it's fleshed out well, hopefully Jesse will sticky it somewhere, and we can just point questions to your table. It'll probably always be a WIP. Shoulda been started in 2010.
I'm a halfway smart fella, but I just get all whim-whammed with offsets, and backspacing, and tire widths, and lifts, and, and, ......
This should explain "Offset".
So, [MENTION=68981]jam23r1[/MENTION] has a great idea with this chart. Here is my first run at it. Only listing 17" sizes right now. I need the measurements of our stock wheels ASAP!
Comments?
Comments?
how in the hell did you come up with this?.......... omg its everything a nobe could want. I love it
Wheel spacers. Are "NEEDED" to stop rubbing on UCA and wider look for tires bigger then 275/70/R17 so this tire is wider than stock but same height
This statement is false. Spacers are not needed to run 285's on factory rims and 275's are taller and wider than stock.
Fixed thanks for the info. And everyone who helped with this!
Trying to understand this. 2014 SR5 premium, 3" lift....will 285/70/17 fit with minor mod? What exactly will require modification?
This was the thread before the thread - so to speak. Check here: http://www.toyota-4runner.org/5th-gen-t4rs/156378-5th-gen-tire-fitment-guide.html#post1550444
That will be a more complete chart. Every tire type is different and I imagine [MENTION=66316]1engineer[/MENTION] didn't get that far into the details for that reason - one couldn't possibly cover every different combination. A number of members here have a 3" lift with 285s - modifications have been anything from pushing the fender liner forward and nothing else, to heavy trimming and cutting off the body mount. It depends on what specific tire you buy and the offset and width (and backspacing) of your wheels, if not stock.
OA
OA
Yes that's true. Statistical analysis gives me well over 1,000 possible combinations without the effect of aftermarket UCA's lol. I made it as simple as possible and still provide reasonable information.
044runner4
