tires
moe2121
Want to put 35" tires on 97 ltd, help
Have a 97 ltd, want to put 35's on it. Need suggestions on how to do this. thanks
You're about to do alot of work just to put 35's on it hahaha why is this the focal point....other than it's gonna look freakin sweet, which it is, if I may ask?
2" body lift, 3" suspension lift, and cut your body and you can make them fit. I know someone that did a 3" spacer lift and cut the fenders to fit them. Check out the post linked previously for more ideas.
I'm running with the big boys, trying to keep up with the rock climbers, looking at a 3" suspension and a 1.5" body lifts, changeing gears to 529. Don't want to cut the body though.
If you don't want to cut, then you'll need a 3" suspension lift AND a 3" body lift. Even then, you might have to cut depending on your wheels. Check out the thread I linked and you'll see a lot of information on there.
Pretty sure they'll fit with that, you'll need new brake lines and all that fun stuff if you go with that, either way you'll still be taking a hammer or a grinder to your pinch welds, if you're running stock wheels you'll prolly want to pick up some wheel spacers as well
AndiGarage
