TIS FSM for 2010 4Runner is here...
There are 2 rm.zip files and 2 rm something else files. When I get zip file 2 it doesn't run when decompressed. Are you saying I need all files before unzipping?
There is only one "RM.zip". There is the "RM pdfed.zip". Look at the last three files in the list(RM.z01, RM.z02, and RM.zip). You need all three rm files in the same directory. Then open the rm.zip file. Same goes for the pdfed version if you prefer.
I need to get back on and finish the wire connector section...I've been too busy though...maybe went the next model refresh comes out...
which wire connectors? You're scaring me now! I'm trying to install the Pioneer Nav this weekend..and i was hoping i had the holy grail in case i need wiring diagrams!
you'll be fine...I'm talking about each individual connector...It gives the part number and other bits... Nothing all that important...
48201d1311906811-tis-fsm-2010-4runner-here-2c.pdf
Not true! The connectosr are very important, it has taken me a good amount of time to find the ones I need. Thank you nashman69g for your hard work. The book and you help is what is making my heated seat project possible.
Has anyone tried the link lately? When I get to the mediafire site it just sits idle and wont load.
Thanks in advance!
Joe
just tried it...no problems for me... check to make sure your popup blocker isn't blocking the window that opens...here are the steps...click the file, it then open a new tab or window with the name of the file and a bunch of advertisement, you will see a yellow box that says "Click here to start download from MediaFire", click it, the yellow box will say "Your download is starting" and a window will popup and ask what you want to do with the file (open or save), choose save and the location, you should now have the file on your computer.
I must be re****ed because I can't get it to work either. I am on a mac with OS X 10.6.8, any ideas?
Hey Cody,
I got it to work using Safari on 10.6.8. Under "file" make sure that pop-ups are not being blocked. If they were, unclick it and then quit and relaunch safari.
This did the trick for me. Also, follow the original instructions for getting the newest stuffit expander and putting the 3 files in one folder!
THANKS NASHMAN!
I'd like to post a not-so-subtle reminder that nashman69g had to shell out a bit of cash to even get this information, much less compile it for all of us to get and use.
Please, be good netizens and at least offer a few dollars (shoot him a PM) in return for what would cost you many dollars to get on your own. I did, as have others, and it's the best "thank you" you can offer.
Thanks,
Mike
Hey Cody,
THANKS NASHMAN!
Edit: I figured it out...lol Thanks man, did everything come ok?
Marshall, I really appreciate you putting all of this together! Beats having to beg the Toy parts/service guys for printouts!!
Do you have the latest TSBs put together for '10/'11? I looked through the MISC zip, but didn't see much of the newer stuff. I think there's a bulletin about the 1st to 2nd shifting problem and some other stuff.
I can also host the download if you need me to.
