Titan Rod Vault?
Thanks for bringing this up. I have a rod vault sitting in my garage waiting to be mounted to my 15 TE with Baja Utility Rack. I have seen a 4th gen with stock roof rails that had one mounted. The issue I see is the hatch. You will have to get the reel case far enough forward so you can open the rear door.
I am curious too see how other have mounted their rod vault. And if anyone is looking to purchase them, they are on sale and $150 off retail.
There is also the "Cadillac" version of the rooftop flyrod holder: the Big Sky Rod Box. Very pricey, but nice. They make a full-length version and a 1/2 length version -- not sure which length would be best on a 4R. Anyone have one and can post a picture?
Sportube double haul
I have the sportube double haul tube that I use. It works the way its suppose to, however, I clamp it vertically (imagine two rods on top of each other versus next to each other). I noticed that clamping it this way, there is a slight bow in the tube. Otherwise it seems to work fine.
They are everywhere around here in Denver, but I guess that's cause they're a Colorado company. I don't use one, but instead I use Sumo Rod Mounts (magnetic). They work great and allow me to prospect down a lot of the spots around here. I usually just break down my rods at the end of the day.
Only problem with the Rod Mounts is that I need to remove them and put them in the T4R because Im afraid of them getting stolen.
This is exactly what I do, those mounts are convenient for multi spot day fishing.
Wtf!!
What are these rod vaults you all are talking about??
You mean, I no longer have to drive with my fishing pole hanging out the window??
Thanks for finding another way to spend $350!!:lol:
For those that aren't familiar with them
For carrying my rods I use one of these Sage tubes that holds up to four 9' 4 piece rods. If I'm driving from one spot to another I just put bungees between the two D-rings in the back and the two rear seat grab handles and slide my rods in. Can get a 9' or shorter rod up there no problem. My 10' and spey/switch rods are a different story...
Not a great pic but you get the idea.
IMG_20150809_194215 by Marc Fossi, on Flickr
Bit the bullet on a Big Sky Rod Box. Very well constructed and going to get a lot of use this year.
Update: the rod vault works with the Baja adapters but it's super high up. Decided to leave it off for my 2k mile road trip.
Picked up a refurbished Titan Rod Vault at their factory...perks of them being based in Denver! After plasti-dipping it anthracite grey, installed them today. If you use the stock TE cross bars, you'll need two spacers for the rear mount, and shorter bolts up front.
Guys at Denver Outfitters were awesome...they already knew what the 5th Gens needed, so he gave me four spacers, which are just the bottom part of the clamp with the threads drilled out. He drilled them out for me real quick. The spacers lift the rear clamp up about an inch so that you can actually open the case. Our 5th Gen cross bars are so close to the roof of the truck. This is the reason for shorter bolts up front...cost about $4 for four 1-1/4" bolts.
Talyn
