to disable or not to disable VSC
but back on topic..... lol VSC sucks in my opinion but i do want the yaw/decent capabilities to help with the gas mileage as i stated before...
The center diff isnt limited slip. -- When locked it lockes the planetary drive setup to send 50/50 power to front rear axles at all times..
Not a conventional limited slip, but the effect is the same. It's between open and locked.
The 50/50 represents equal rotational drive shaft speed, but torque follows available wheel traction so front/rear drive shaft torque can be anywhere between nearly 0-100%.
So, with the rear end jacked up and front with plenty of traction, torque to the front drive shaft would be:
Locked -- nearly 100%
Open -- nearly 0%
Torsen T3 -- 53% which in this case would have the same result as being open.
hey JB i've got a similar pic of your avatar!!
Cool. I guess having done it makes it easy to recognize what's going on. I've had some comments from people that indicated they couldn't tell what it was a pic of.
jb I think where on the same page with the driveline stuff just explaining It slightly different... I was making coffee in mine that morning camping what were u cookin up... what stove was ur pot cookin on I run the msr pocket rocket with the GSI mini dualist cook set ...lots of backpacking/survival in my back ground
Yeah, no doubt. It's hard to put it clearly in words.
jI was making coffee in mine that morning camping what were u cookin up... what stove was ur pot cookin on I run the msr pocket rocket with the GSI mini dualist cook set ...lots of backpacking/survival in my back ground
Coffee in a Jetboil.
Lots of day hiking. As far as survival, well, I'm still here so I guess I got the minimum covered. :bigok:
