Torn CV boot
mlc2000
Have a torn CV boot. Is there a kit I can just use to repair it without having to take it somewhere and have them replace the whole dang axle?
I do have 4wd so not sure if the repair is any different than on a 2wd.
It's a pretty common issue. Common enough that there are lots of threads on your various options. I'd suggest just using the search function to find related threads. You'll find a lot of useful information.
You can replace just the boots, but the common wisdom seems to be to just replace the entire shaft (especially if you're considering DIY). You get fresh assemblies, seals, and boots - and the removal/install process is a fraction of what it takes to replace a boot. Not too much extra expense, either. See here.
If you want to try replacing the boot yourself, see here. -How long has it been torn, and is there still grease in the CV joint (and no grime/grit in it)? If the joint is worn, you'd do better getting a fresh shaft as well.
I'm pretty sure the repair is different on 2wd - they don't have any CV boots (or CV joints) to worry about, so no repair needed! :)
Hard to tell how long but there is grease still in there and not much grease outside. Don't see any grime or grit though.
If it's a pavement princes, just get an over the counter axle and save the time replacing. Times money.
To messy, making sure you have the right side put together and not all score on joint area.
From someone that has no problem doing things myself to save a buck.
I am in the minority. Replace the boot. They are $15 bucks on eBay. Easy afternoon job. Watch a video on YouTube. Easy do it yourself project and if the boot fails, what the heck it's $15!
I did a inner boot, it was the easiest cv boot I have ever done. Release the outer clamp, release the inner clamp and it falls apart. Remove a c clip, take off the inner bearing, put on the new boot and install new clamps and away you go.
If there is still clean grease in there, you are good. Full of grit, get a new shaft.
/\ there's the key word there.... If there's grit in there get a new shaft...
After you pulled it out and apart...where do i get one now to put it together....wishing you just bought a new axle about now N been done.
Unless you're going to try one of the split repair boots, replacing the axle is less work than replacing the boot unless you're going to try MFreund's method. Sounds like he left the axle in the knuckle and only removed the xfer case end.
If you've got any DIY skills at all, it's a couple of hour job. There are videos for 4Rs and FJs, including showing it done as a trail repair. In addition to some excellent write-ups. If you've got a jack, stands, and basic tools, you're good to go. The only relatively non-standard tool is the big axle nut socket, but you may be able to borrow one of those from a loan-a-tool place (Advance, Autozone, etc.).
Some folks try to knock the non-Toyota axles, but the new NAPA axle (Cardone) I chose was visually identical to the OE axle it replaced and only $80 with lifetime warranty. And the OE axle I took off was in better corrosion shape than the supposed OE reman'd that I let the local dealer put on a few years ago.
People swear by someone called CVJ or something like that who claim to only sell reman'd OE axles, but I don't see how they could tell the difference if I sent them my NAPA axle as a core.
-Brent
utkrstam
