KidVermicious
Does Torque Pro supply long term fuel trim data? I'm fighting a p0171/p0174, and the free version of Torque isn't giving me the data I need.
mind you this is the pro version I have.
looking thru the data graph section you can do :
line/scatter chart
you can select x/y axis for this sensor
fuel trim bank 1 long term
fuel trim bank 1 sensor 1, 2, 3, 4
fuel trim bank 1 short term
fuel trim bank 2 long term
fuel trim bank 2 sensor 1
fuel trim bank 2 sensor 2
fuel trim bank 2 sensor 3
fuel trim bank 2 sensor 4
fuel trim bank 2 short term
max data points up to 5000
log interval up to 1000 ms
but the problem I see is that none of those sensors show up as green but it could be my obd2 reader or that I haven't plugged it in for several updates since last year, not sure.
now if you found the pid manually and entered it, it may work better than using the default setup from torque, aka trans temp pid since the default app settings cant even pull the trans temp itself.
line/scatter chart
