Torque Pro users
KidVermicious
Does Torque Pro supply long term fuel trim data? I'm fighting a p0171/p0174, and the free version of Torque isn't giving me the data I need.
Damn I just gave away my adapter and old android that I used to a friend. if you have an old android your not using for anything else ill pm you my google play login so you cab download my torque pro and see before you spend the money
mind you this is the pro version I have.
looking thru the data graph section you can do :
line/scatter chart
you can select x/y axis for this sensor
fuel trim bank 1 long term
fuel trim bank 1 sensor 1, 2, 3, 4
fuel trim bank 1 short term
fuel trim bank 2 long term
fuel trim bank 2 sensor 1
fuel trim bank 2 sensor 2
fuel trim bank 2 sensor 3
fuel trim bank 2 sensor 4
fuel trim bank 2 short term
max data points up to 5000
log interval up to 1000 ms
but the problem I see is that none of those sensors show up as green but it could be my obd2 reader or that I haven't plugged it in for several updates since last year, not sure.
now if you found the pid manually and entered it, it may work better than using the default setup from torque, aka trans temp pid since the default app settings cant even pull the trans temp itself.
line/scatter chart
trans temp works, you have to pick Trans temp #2 instead of #1
Need Pro to access the settings.
line/scatter chart
I think this is what I needed to know. Thanks!
CoaterZ_FL
