torque spec question
ltdrose
Does anybody know the torque spec. for the upper control arm to frame bolt. I can't seem to find it anywhere. All it said in the instructions was torque to manufacturers spec. which I don't have. 2011 sr5 4x4 Thanks
oopss my bad.
just found that.
(a) Tighten the nut.
Torque: 115 N·m (1173 kgf·cm, 85ft·lbf)
what the hell are they talking about in step 1(b)???
Awesome, thanks guys saw that download link just not real computer savy (no clue how to make it work)? Thanks again.
oopss my bad.
just found that.
Oh , I see where you got that. That 71 in/lbs is the bolt that holds the ABS wire bracket on.
To the OP , Your also supposed to stabilize the suspension before torquing it.
per manual...
Hand tighten nut then
install wheels
. STABILIZE SUSPENSION
(a) Lower the vehicle.
(b) Bounce the vehicle up and down several times to stabilize the suspension
Torque to 85 ft/lbs
per manual...
install wheels
Torque to 85 ft/lbs
Ya missed the bounce up and down part ill re-check the bolt after a good cruise I figure by the time the bushing go out those fancy 1100 uca's will be a bit more reasonably priced. Thanks for the info not a ton of info out there like the 3rd gens but people are really starting to mod the heck put of these things.
