Total chaos UCA issue
arehman11
I’m trying to grease my UCA but my zerks aren’t accepting any grease. I’ve pushed the ball in and they seem to work fine. I did loosen the through bolt as well. Is it possible they are clogged and would heating them up help?
Gotta loosen up the UCA bolts prior to greasing the zerks, if not no grease will go through the zerks.
Yeah I loosened them up to where I could spin the nut off with my finger. I think my issue might be the end on my grease gun. Going to try a different fitting and see if that helps .
all of them? check the grease gun nozzle for any grit. I use a lock n' lube coupler, and I recommend it
one of them? replace that zerk.
thadjay
