Towing a U-HAUL 6 X 12 Trailer 3000miles One Way Questions...
4RunnerStunner
Hey All,
I decided to start a thread because I a concerned and want to make sure that I have everything right for this first tow and need any input I can get on towing this U-Haul.
Well, I have a 05' T4R V6 2wd and have the stock hitch on. I have ordered an External Tranny Cooler and have to buy the hitch ball and locking pin and 4 pin adapter I think. The question I have is what do I need to get and will my 4RUNNER stock hitch be able to handling that weight? I know the Tongue weight max is 500lbs and I have a class 3 hitch rated at 5000lbs. Empty weight of trailer is 1,800lbs and I dont think I will go over 3200lbs loaded. Any help from veteran towers would be greatly appreciated. All fluids are changed to synthetic so no worries there. I just want this trip to go smoothly as possible.
When towing a trailer one must develop a TOTALLY DIFFERENT way of driving compared to the way most people drive when not towing. Here are a few examples:
- Look MUCH further down the road. Towing requires that one SEE situations WELL BEFORE you are actually right in the middle of them.
- Resist the temptation to make SUDDEN lane changes and brake TOO HARD and TOO LATE. Steady and predictable driving is KEY.
- SLOW the heck DOWN. Regardless of what others might say one should not tow well over the posted speed limits or too fast for road conditions. You need more time and more distance to stop. Speeding + towing lengthens stopping distance and increases the risk of an accident.
- Using CRUISE CONTROL when towing is a NO-NO. The increased weight and mass of a trailer can cause the cruise control to speed up/slow down in a very unpredictable and NOT VERY SMOOTH MANNER. Towing without cruise control lets one take advantage of one's momentum and gravity. When used properly, the physics of towing is your friend.
- Take Turns much WIDER than you normally do. Remember that your 4Runner is now longer just 16 feet long when towing. In your case you are now pushing 28-30 FEET LONG.
- Do not get too close to the side of the road. If you get the trailer's tires off the edge of the road you will be in SERIOUS TROUBLE. Also on two lane roads you would not believe how many home owners have their mailboxes sticking WAY TOO FAR out onto the road. Some home owners also park their vehicles on the edge of the road that stick out onto the edge of the road.
With a 6 foot wide trailer this is not as important as with an 8.5 foot wide trailer but a good practice none-the-less.
- In some states when towing a trailer the tow vehicle and trailer are considered a "Truck" and are supposed to follow road sign instructions for "trucks". If you see signs like "No Trucks in Left Lane" you might want to stay out of that lane. Also do not be surprised if when towing a trailer you are told to pull into a commercial truck checkpoint. I have had to do that on accassion even though my tow vehicle and trailer are "not for commerical use". When I got pulled in they checked the weight of the trailer, it's general condition and that it was properly registered, inspected and that tow vehicle insurance was current.
In your case, make sure you have the U-Haul rental agreement for the trailer with you at all times.
- When towing and you stop for gas or breaks ALWAYS take a walk around you tow vehicle and trailer. Visually, check the trailer's tires conditon, hitch, safety chains, wiring plug, etc.
- Avoid unnecessary lane changes when towing. When you are in the right lane of a highway that has an on-ramp (with a yield sign) that intersects with it do not move over for someone on the on-ramp unless you ABSOLUTELY HAVE TO and it is SAFE to do so. If the other person fails to YIELD and hits you THEY are at fault. If you change lanes to let them in and you have an accident YOU are at fault.
- Before starting a towing trip ADJUST you mirrors for towing.
Depending on the width of the trailer being towned it may be necessary to purchase additional mirrors. With my 8.5 foot wide car trailer the standard 4Runner mirrors are simply not enough and pose a SERIOUS Safety hazard if used by themselves. I cannot stress enough the importance of reducing/eliminating BLIND SPOTS when towing. Blind spots are one of the chief causes of accidents involving trailers.
- When towing turn the tow vehicles headlights on even on a Sunny day. Anything to increase the visability of your tow vehicle and trailer is good. Believe it or not when I tow, other drivers have not "seen" my BIG, Silver, Car trailer with red & white relective tape on it.
Wow, thanks for that information!!! Most stuff is common sense and I do not plan on driving like a mad dog with this thing. Lives are on the line here!! One question, Will a 2x2 hitch drawbar from Wally world work? I have read that Toyota made this hole undersize and wanted to know if the 05' model has been corrected.
If I may ask, what trailer are you pulling? I'm in a position where I'm thinking about towing a U-Haul trailer from California to Texas in the next 6-12 months. Please post back and let us know how the trip went.
Also, like an idiot, I figured I'd never need a hitch - I never needed one before. Of course, now that I have a vehicle that CAN tow I'm wishing I got one. What's the best way to go about getting one installed? U-Haul has said they'll install one for about $320, but I'd sure like it if it looked factory. Don't mean to hijack the thread - there's a lot of good info in here I'm going to save away. Thanks!
Inspect the trailer yourself. UHaul does a decent job with maintenance, but the fact that these pieces move all around the country makes upkeep dificult.
Check all four tires for uneven wear and that they match.
Have the surge brake tested. If it is in good working order, it will make braking a lot easier for you. The reservoir should be near full with clear (not cloudy) brake fluid. Make sure the trailer comes with 3 chains. The 3rd one activates the brakes should something bad happen.
You wont need additional mirrors for the 6x12
Read the manual that UHaul provides. Make sure the weight in the trailer is distributed properly.
Thank you all for the information!! Keep them coming!! I do have another question, does the 6X12 come with the WDH on it, because if it does, can it be removed since I have the factory hitch on my 4runner?
I moved from Denver to Phoenix late last year. I have an '07 v6 4x4. I pulled a U-Haul 6x8' that weighed in around 2200 lbs. I had a hitch installed at Toyota before I left (I think the only hitch available if not installed at the factory is the one for the v8). It's rated at 7200 lbs., I believe. I too was worried about pulling it especially over Raton Pass in New Mexico. Honestly, at times I forgot it was back there. I did use over drive and cruise control without any issues and kept my speed down. Each stop I would do a walk around, as mentioned earlier by Charlier180. I loaded the trailer properly and was very alert the entire trip. No problems.
I think Toyota mentions trailer brakes for anything over 1000 lbs. The trailer I had didn't have them. I thought the next one up, the 6x12' did. Will you be using trailer brakes ?
DJJ
DJJ
Yes, the 6x12 has surge brakes. I think since the 05' model has 5 gears, I should be ok. Rpm's at 65mph in 4th is like 2500rpms which is not bad.
Hey Guys,
It has been a while but I made it 3000 miles to from South Carolina to Washington State!! It was a wonderful ride! Towing the 6x12 trailer was no problem at all for the 4Runner. I even went up to 75mph with it and was able to drop it in overdrive going through the plains of South Dakota. It a great experience with the truck but was so happy to get the trailer off to regain my gas mileage! I was down to 14.5 miles a gallon towing! The ride was very smooth and she handled well. I thing I was towing about 3500 pounds but did not feel it until I was doing some hill climbing.
I've towed a 6x12 Uhaul trailer from Denver to Seattle and back and made two trips towing a 5x8 from Denver to Grand Rapids. I've never had any issues. Glad to hear your move with the trailer was uneventful as well.
Towed a 6 X 12 U-Haul from CA to MI a couple summers ago with my Tundra, only issues I had was with the cheap (not inexpensive) 4 - 7 pin adapter I got from U-Haul. Piece of crap, trailer lights kept going out. Glad you had a good trip.
Hey Guys,
Glad you made it safely. I left SC (James Island) about 5 years ago .. good thing I still have family there so I can make plenty of trips back! Enjoy Seattle, I love it out there.
Yeah, that 7pin adapter does suck!! Too loose for my taste!
Thanks and Seattle is cool and loving every minute of it! Only problem I have is that I have to get use to seeing traffic on a Sunday which is bananas!
patnewton
