Towing my TT for the 1st time!
I towed a 29 feet TT two years ago with a 2005 GMC sierra v8 long bed ext cab. I don't feel like I am abusing the 4r more than I did with the sierra. I am so used to drive the runner empty that i feels funny to actually see it working!
I'm sure stock it would handle it pretty well, but for peace of mind I bought a Scangauge 2, which is really great to watch all the fluid temp (trans and engine) and engine load, changed brake fluid and pads for heavy duty. Added SS brake lines, rear air bags and new tires.
What kind of temps do you see on your scangauge in stop and go driving around town?
(without the trailer)
Depends of the outside temp, but on a 75-80f day, it is between 155-165f, max I saw was 170.
In winter time (0-32f), it is around 115f.
I just made my 1st trip this weekend also.
I have a small pop-up that weighs about 1500-1600lbs loaded.
Everything seemed to pull nicely, plenty of power with the V6 in 4th gear.
Nice trailer....That looks like the 8' box. I have an 03 Coleman (made by Fleetwood) 10' box. Then Fleetwood and Coleman had a falling out..and they stopped making the Coleman trailer. Actually they still made the trailer..but just didn't put the Coleman name on it.
Then in 2008 the plant that the Fleetwood trailers were built at was sold to an investment firm. Then in 2011 they closed the doors.
Now some other camper trailer company has bought the plant and has started building the Fleetwood trailers again.
I LOVE my Fleetwood (aka Coleman). Very well designed...and very well built. Perfect for a small family.
My transmission is brand new and I drive like an old man.
Mine rarely breaks 200 degrees unless I'm off roading etc. I think I need to have the fluid flushed and see if I have a frozen caliper. I'm running a tranny cooler too and that helped a ton
My 03 v6 didnt come with one either and I have the tow package.
I tossed in a big hayden cooler. I have to put in a temp quage.
Yep,
Fleetwood bought Coleman, than discontinued pop-up trailers. Glad to hear someone picked them up. Who is it? Be nice incase we needed parts.
Well, I added tongue weight today and lowered the tongue height another 3/4". That seems to have helped my bouncing by about 80% better. My battery was sitting next to LP gas tank, so I moved it forward to it's intended position. I also re-loaded cargo and put heavier stuff towards front.
I tried a 8" drop, but it kept pulling my plug out, so I had to go with 6" drop.The 8" drop put my trailer 2" lower in front verus back and I thought it was more stabile. Just didn't get to drive far due to plug not reaching.
I am going to try to measure tongue weight today yet.
So, the rear of my tow vehicle now compresses 1 3/4" with the trailer hooked up 22" center of axle to fender.
Front is 21 1/4", so I still have a little rack, not nose high.
The box on the trailer is pretty much level at 16" front and rear. Should come down a little with the tow vehicle completely packed out. Good for now.
I'll add info on tongue weight wjhen I get it.
Best regards,
Doug
Yep,
So, the rear of my tow vehicle now compresses 1 1/4" with the trailer hooked up. 23 1/4" no trailer, 22" with trailer. (center of axle to fender.)
Front is 21 1/4", so I still have a 3/4" rake, not nose high.
Best regards,
Doug
YOu can get an extention for the plug
Yep, I looked into it.
They only had 4' extensions and they were $62.
I am satisfied with where I ended up. I think I might have seen swaying with the 8" drop anyways. Thanks for the heads up though.
Best regards,
Doug
What?
Wow are they made of gold? I have seen them for much much less than that.
You can always just make a plug set up then it would not cost way that much.
All the parts are at walmart .......well the walmarts by me at least.
Thasts some crazy pricing.
Best regards,
Doug
Mine runs quite a bit hotter than that. Kind of worries me.
If you have an oil cooler, you could look at your thermostatic fan to make sure it works properly. When driving at low speed and 80F outside temp the fan works almost all the time and I can see the temp going down with it.
