Towing question
2DaMtns
So I am likely going to be moving in the near future (before it gets too warm), and I have a question about towing. I have a stock auto 00 limited and will be towing a 98 Honda Accord auto with a dolly. It will be a 450 mile trip on the interstate, some of which will be going through WV and will be hilly. Will the stock auto tranny hold up or should I consider a tranny cooler or other mods? Thanks in advance.
Tranny cooler is nice to have anyway but you should be ok as is since you are well under the towing capacity of 5000lbs.
Thanks Ron. I knew the towing capacity was listed at 5000 lbs, but I didn't know if that was an actual, real world number or if it was the rating for towing on the Bonneville flats. I thought I'd be good, but I wanted to make sure before I throw out my tranny half way between here and Charlotte. Thanks again!
When towing, lock out overdrive.
Are you renting a dolly. If so make sure it is in proper condition. Have them show you how to hook it up and unhook it to the truck and how to hook up the car. Avoid U-Haul.
I would definetly recommend a tranny cooler. I was thinking if I had to tow a car and what the weight limits would be. U-Hauls car dolly weighs 900lbs. plus whatever you are towing. I also don't think that they come with eletric brakes either so be careful when getting ready to stop.
