toyota 4runner 2004 Sport
cmcgrail
I have a problem here, i have the XREAS shocks on the back of my 4Runner and i have to change them, i want to put a lift kit but with this suspension, i cant. is there any way of bypassing this to change it? any other opitions?
What is Xreas exactly?
http://www.toyota-4runner.org/4th-gen-t4rs/54365-what-xreas-exactly.html
Installation:
Although I do as much work on the 4R myself as possible, both maintenance and mods, Working on the suspension is not really something I wanted to do. Through my research on lifting the 4Runner, I found that it is pretty straightforward without XREAS, but having an XREAS equipped 4R makes the job a different ballgame, one in which your local shop has most likley not encountered. You cannot disconnect the XREAS hydraulic lines connected to the shocks at all. Once fluid leaks out and air enters in, the system needs to be entirely replaced. There is no way to flush or recharge the system. So this job requires working in the wheel well with handheld spring compressors. Additionally there is the Skid Control Sensor wires right there that cannot be stretched or damaged. Same goes for the brake lines. Various shops I spoke with would have nothing to do with a job like that, with them taking responsibility for potentially runing an expensive XREAS or ABS/Traction/Skid Control system, and not being able to use their wall mounted compressors. Actually, after talking with a bunch of shops, I did not want them to touch my vehicle afterall. I would have to stand over them to make sure the job was done to my specs and guide them through the job, paying for many hours of labor. So I decide to do it myself.
Daystar Spacer Lift 2.5/1.5
2007 Toyota 4Runner Sport Edition Lift
via J.A.
The only way to retain XREAS is to get a Spacer Lift.
XREAS stands for "Cross Linked Relative Absorber System".
X-REAS was designed to help improve vehicle on-road handling performance. This technology links each of the vehicle's shocks to it's diagonal counterpart via a gas hydraulic chamber. During cornering or when traveling over bumpy surfaces, the gas hydrauilc chamber acts like a bank "borrowing" fluid from the cross-linked shock bearing the least amount of force and "loaning" it to the shock sustaining the greatest amount of force. This exchange of fluid helps the 4Runners wheels maintain contact with the driving surface and helps lessen vehicle body sway, pitch and roll, making for a more comfortable ride.
Daystar Spacer Lift
via J.A.
Photo J.A.
X-REAS Picture
http://www.toyota-4runner.org/attachment.php?s=&postid=96905
via Luxury
How To Identify X-REAS Suspension
How to identify X-REAS suspension - Toyota - 4Runner . org Forum
via dingo, J.A. & Uneek
Some members did baby steps by going w/ a Spacer Lift & many members Did It Right The First Time.
I currently still have my Daystar Spacer Lift...after 2 month, I was ready to upgrade. I haven't upgraded yet, because the wallet won't let me!!
Anywho...I was reading about Daystar Spacer Lift for over a year if not two. I landed a Used Daystar Spacer Lift Kit & was hyped up to install them. If you don't know how to do suspension, you'll easily spend $300 on labor alone. Good thing I have a friend w/ a shop, I was able to help w/ my supervision as a peace of mind. My goodness...all that work just for a slight increase. If I did it all over again...I would go straight to Coilovers.
I have the Daystar Spacer Lift & I was drooling over it for a year till I finally caved in.
It definately looks nice, but it's the same travel as stock, because you're just adding a spacer to extend the stock strut/shock assembly.
I actually help do the install & it's so much work for so little improvement.
I don't regret doing it, because if I didn't do it, I wouldn't have known this information.
If I did it all over again, I'd go with...
• OME
or
• Overland Warehouse Radflo 2.5
I didn't replace my UCA, because I stuck only stepped up to 32" tires, if you were to step up to 33" or higher, then you need them for clearance.
As for alignment...only the Toe Angle for the front are adjustable, and my Caster Angle wasn't out of whacked too much, my vehicle is traveling perfectly straight.
If you need photos or have questions about the Daystar Spacer Lift...please let me know. Actually if you need a Tutorial in installing a lift, let me know.
Post #2
http://www.toyota-4runner.org/772392-post2.html
Post #6
http://www.toyota-4runner.org/772656-post6.html
Post #9
http://www.toyota-4runner.org/774714-post9.html
Full Thread
http://www.toyota-4runner.org/4th-gen-t4rs/88736-daystar-lift-questions-opinions.html
If I was able to remove the Spacer in a blink of a second from a Magic Genie...I'd let you have it.
...Please don't hesitate if you have more questions...
Cpn2mss
