Toyota 4runner Buggy - Built!
CGuava
Toyota 4-runner Buggy
Located in Castle Rock, Colorado 80109
kexkoz.jpg~original
Fully built Toyota 4-seater (5 seater actually, with a full width factory bench seat).
Built this rig with all parts that I could dream of to build it once, and it has worked flawlessly for the years since complete.
I have the title/BOS from the last owner, but have never registered it, I just buy OHV stickers for it as it is trailered everywhere. I would assume that you can register this wherever you live, and can license it for street use. I never had the need or desire. This has only driven on less than 1 mile of asphalt (moab) since I completed the build.
Selling because I bought a new buggy. Please don’t lowball me. Only trade I would be interested in is a RZR 900/1000, 4 seat preferred, but would consider a 2 seater
Completed the build in 2010, have wheeled all over Colorado and Moab with the rig, and it has performed well on all extreme trails.
Specs:
83” Wide
75” Tall (at the top of light cage)
113” Wheelbase
Engine/Drivetrain:
5VZ, 3.4L Toyota V6, top end rebuild prior to engine swap, no reason for rebuild, just to open it up and take a look
Diehard Platinum Rear Mounted Battery
RCI 15 gallon fuel cell
Taurus Fan on Griffin Radiator
Thermally controlled fan
Manual Trans (G58, 5 spd)
Marlin Dual Transfer Cases (MC08), 2.28 first transfer case, 4.7 rear case
Driveline Specialists Drivelines, 1350 axle ends, Toyota Flange at T-case end
Front Axle:
1979 Ford Kingpin Dana 60, axle re-tubed to be passenger drop
5.13 Yukon gears, Detroit Locker
Yukon Chromoly Axles (35 spline inner and outers, factory lengths, so you can buy parts at NAPA if needed)
Yukon Superjoints
Blackbird Customs Caliper bracket setup (works with off-the-shelf chevy brake calipers)
Assembled with all new parts, bearings, races
Full hydraulic steering ram (Surplus Center Ram), PSC end-links
Deadenbear/Reid Knuckles and Inner C’s
Rockstomper steering arms
Front Suspension:
Front 3-link with Panhard (1.5” .250 DOM)
2.5”x1.5” 0.250 wall lower links with weld on Johnny Joints
Upper link of 1.75 DOM with Johnny Joints
14” Sway Away Emulsion Coilovers (2.0)
4” FOA Air Bumps, shortened to 2.5 inch travel
Limit straps
Rear Axle:
1979 Ford Dana 60, spindles bored open to accept 35 spline rear axle shafts
5.13 Yukon Gears, Yukon Spool
35 spline Yukon Axle Shafts
Disk brake conversion, Chevy Calipers
Trussed
Rear Suspension:
4-link with near parallel lowers
1.5”x2.5” .250 wall lower links with weld on Johnny Joints
1.75” .120 wall DOM upper links with weld on Johnny Joints
16” Sway Away Emulsion Coilovers
Limit straps
Wheels/Tires:
39” Sticky Krawlers, these are the super sticky half-tread compounds. They work insanely well
17” Raceline Monsters
Wheels have been siliconed to prevent leaks and burping
Included with sale/trade:
M8000 Warn Winch, steel cable (I’m not a synthetic fan) with front suck down capability
Tantrum Rock lights, with wireless controller
4 overhead VisionX 8” lights
Cut-to-length Hi-lift Jack, never used on this rig, but easy access and not buried
Artec Quart Crate with spare fluids (included)
Extras:
I have a ton of spares for this thing that are included. Spare 35 spline stubs, spare inner axle shafts.
Features:
4 full, adult seats, 4 point harness up front
Fold-and –tumble rear seat allows for hauling gear, or passengers depending on the trail
AM/FM Radio with 3mm input plug-in for iPod/phone/etc.
2 6x9’s in the rear doors
Cage built with 1.75 DOM/HREW Tubing
2x6” rock sliders beneath body section
4 half-doors
Rear doors are welded shut, and do not open, should be able to install full doors if wanted
Featured on the cover of Crawl Magazine
Worthy of noting:
There is some body damage to the rear passenger door and driver front door
Some of the Johnny joints could use a repack as they may be loose
Asking Price:
$14,800
Pics:
mwxjiq.jpg~original
166394_495143048392_299453208392_5922715_603953_n.jpg~original
Suicide%20Hill_zpspg36v2ai.jpg~original
Helldorado%20Entrance_zpsk4tmber5.jpg~original
Car%20wash%20Drop%20in_zps0tpxenj6.jpg~original
Escalator_zpsbbltffu5.jpg~original
5b1b1c16.jpg~original
Video (have to search through some of them):
https://youtu.be/f-BPd__EUY4?list=FLaQPQT8wmVG8Df8jhKF87gA
https://youtu.be/6ez_8JP0Y0w
https://youtu.be/UOtZqETIidU
https://youtu.be/AYW5F4wDiXE
Build thread:
Project "A lot of ideas from Pirate" 4runner - Pirate4x4.Com : 4x4 and Off-Road Forum
Features:
4 half-doors
*Sunroof (Key in getting the wife/girlfriend's approval)
H.Sikina
