Toyota inclinometer Colorado Springs, CO
SV_Dude
Moderator
I have an inclinometer for sale. I have had this for a few years and swapped the dash pads. It's in pretty good shape but there are a few flaws. For starters, when I first got it I scuffed up the housing and painted the housing using SEM high build primer, SEM texture coat and then SEM gray to match my dash. It's been a few years since I have done that and the paint still looks pretty good but there is one spot that isn't perfect but still looks pretty clean.
Cons:
The original lighting plug was cut but still has the two wires for the internal lighting.
One of the knobs is missing, I believe it's the lock knob.
Missing the two small screws that hold the housing to the meter
Missing one of the 4 10mm mount nuts.
Pro's:
It's still in very very good shape
Works excellent and all dials move smooth
Altimeter is fairly accurate (I live at about 6000 ft and have gone up to about 13000 ft and it is accurate within a hundred feet or so).
Pics:
The one flaw in the paint:
The flaw is barely noticeable but I don't want the buyer to have any surprises.
I'm located in Colorado Springs and am asking $100 plus the ride (probably about $15). I will accept paypal or cash for a local sale.
if only I had a spare $100 at the moment.
Incase I can come up with the $ what year is it for? Min is an 89 & I hear they mad a change to the dash in aprox. 86
I don't know what year it came from but I believe all the dash frames are the same. I think they all have the 4 holes pre drilled in the metal frame. It should fit if you drill from the bottom of the dash. No promises though.
There are two kinds, long tray dash pad 84 - 86 and the short tray dash pad 87 - 89. The inclinometer cover 84+ wont fit the 87+ and vise versa.
I just laid the cover alone on my dash that is an 84-86 dash and it sits flush on it. So I am guessing that my inclinometer is for the 84-86 dash. I never knew that there was a difference in the dash pads as far as the depth or width of the indent in it. I don't know how this will fit on an 88+ dash pad.
Going off of the info above, no. Apparently it won't line up very well but I don't know if it will bolt up to it or not.
