Toyota owners seem to be a fickle group
Player 10,000 has entered the game...
I think the biggest issue isn't with what Toyota is putting out, it's with expectations of what the 4Runner is/isn't and what it should be. It isn't a rock crawler, and Toyota didn't intend for it to be. To me, Toyota's intent with the 4Runner is to provide a street vehicle that can get you through mild to medium off road situations. It's an overland (cliche term, I know) or expedition vehicle, not a rock crawler.
This video provides good insight on tire selection for overland/expedition type vehicles, which I would personally tend to agree with. The obstacles Toyota had in mind when equipping the 4Runner don't really require 35" tires, a solid front axle, or a front locker. Granted, it is possible to fit them, but it just wasn't meant for them.
Why International Overlanders DON'T USE HUGE TIRES - YouTube
TLDR: If you want to fit big tires, get a Jeep or new Bronco. The 4Runner's intended purpose doesn't really require big tires. If people were honest with themselves and what they wanted, they'd realize that maybe the 4Runner isn't the right vehicle for their intended use.
Absolutely agree on the rock crawling aspect. That being said, it'd be nice to be able to fit 33s without having to trim a little or removing the mudflaps.(the biggest size one would ever need for overlanding imho). Well at least its not that much work to fit 33s!
Facts would involve numbers and analysis. This, crap about 5sp or 6sp, is like a bunch of drunks in a northern Wisconsin bar and JB will try to ride his snowmobile home when he get thrown out and end up in a ditch.
Gear ratios? Are those numbers? The way it works is the engine rpms are reduced by the net gear ratio and the torque is multiplied minus losses. If you know the load at speed (how much power is required) using a brake specific fuel consumption map (bsfc) you can calculate the thermal efficiency and target the peak efficiency.
In this case - because of the math I explained earlier - a 6AT with 4.56 diffs would have the same highway cruising condition as the 5AT, but also gain significantly better torque multiplication in 1st gear. Better towing. Better low speed control. That's why Toyota does that in almost every modern vehicle it makes. The 4Runner is the outlier. In fact - it may be the only suv currently in production with a 5AT. There is no harm. It only would provide benefits.
A bsfc map looks like this:
This is a more complex chart. This is for an atkinson cycle engine and has multiple peak zones under different engine conditions.
Comparison-of-two-BTE-engine-maps-Tier-2-fuel-EPA-BTE-map-from-benchmarked-Toyota.png
These charts explain why it matters to have more gear ratios in order to optimize efficiency over a wide range of loads - like with bigger tires, more drag, towing, etc. This is why 8 and 10 speeds exist - to target peak efficiency under more conditions. It's that simple. And it works. IF done right - you can run that lift without a big fuel economy hit, or put on a roof rack, or tow a trailer, all while maximizing efficiency.
4Runner is in the shop for some body work from a gutless jackass who side swiped my parked truck and ran.
My rental is a new Durango. I could not believe the verbal and physical assault the Durango placed on me when I parallel parked. The sucker wouldn't stop yelling at me with beeps and the auto-braking caused me to crap myself. I thought I hit or broke something. The nanny features for clueless suburban drivers SUCK!
Give me back my simpleton 4Runner!!!!
jeeze sorry to hear about the truck! that would boil my blood
Durango parking assault.. i mean assist :lmao:
You definitely need to turn that stuff off you get in. Even safety sense the new 2020 seems a bit much....tho i do like the sounds of that radar cruise control
[MENTION=118321]Jetboy[/MENTION]
Appreciate the explanations and graphs, but I'm struggling with my "real world" experiences to see the gains in fuel efficiency by running a 6AT and 4.56 gearing.
Here's what's clouding my thoughts; my 2015 Sierra ext cab (granted, probably lighter than my Tundra crew cab) had a 5.3 V8 and 3.73 gears if I remember correctly. It would return 16.5 in city driving, and 21 hwy if I was nice to it and conditions were right. But it liked to rev and I always felt like I had to whip it to get it going.
My Tundra with 5.7 and 6AT with 4.30 gears is returning at best 14.5 if I drive like Grandpa in city, and the best hwy I've returned is 18. Granted, it's still "green" at 2100 miles... however, I can lope along with traffic at lower rpms and use the torque to keep up (most likely due to where hp/tq is made in the rpm band of the 5.7 vs 5.3). No doubt this will haul/tow better on the low end than the Sierra. While I do enjoy the driving experience MUCH more with the Tundra, I don't see fuel efficiency being a gain. Or was efficiency you mentioned energy transfer in general? But still... wouldn't more efficient energy transfer = better fuel economy too?
I'm trying to imagine 4.56 gearing in a 4R on a factory set up intended to appease the masses... and after the Tundra at 4.30 with a 6AT, I can't fathom that being livable for the daily driver behind the 4.0 (on stock tires it seems like waay too much gear to me). But I could be wrong, wouldn't be the first time.
You have to keep in mind that JLs require slight modifications to fit 33s, too. The axles, suspension, and fenders on a Rubicon are all slightly different that the Sport and Sahara trims to accommodate 33" tires. The new Bronco has different bodywork to accommodate 33" and 35" tires between the trims/packages. The fact that the 4Runner needs the fender liner mod, BMC, and either different wheels or spacers to accommodate bigger tires suddenly isn't so aggravating when put into that context. The only difference is that Ford and Jeep do that stuff at the factory, whereas Toyota doesn't.
ahh good to know! Thought they could just slap on 33s on the Sports. My brother in law bought a JL Sport and slapped 33s on it right away. But...he doesn't really offroad so I guess there would probably be rubbing somewhere on the fender if went.
How many Jeep owners, as will the new Bronco owners, add new suspension and make modifications to run 35, 37 even 40’s? They are all over the place in SoCal. As I stated in a previous post, and have others, the 4Runner is not really in the same category as the Jeep or new Bronco. It is a larger, smoother family SUV that has very good off road capabilities and will get you there and back for years without issue. How many 10 to 20+ year old 4Runners with 200k+ miles have you ever heard off rebuilding their motor, transmission or diffs?
My question still remains, can you refute his statements (or the other's statements)? You saying they did their homework doesn't really add to anything. If anything, you look like the guy at the bar who has had too much to drink. Constantly arguing with no substance.
Also, one of the Bronco engineers did bring up the value of an SFA in an interview and explained why they ended up opting for an IFS...You can look for that if you'd like.
Speedy I'm not the one who introduced the 6sp vs 5sp thing. I dont have to prove anything. JB has not provided data that would show a mpg or performance improvement financial data... Nothing. He copied a bunch of crap of the net, and wrote pages and pages of spew and his conclusions is "its better". He would be tossed out of virtually any engineering design review meeting and his boss would have a talking to for having him waste everyone in the rooms time.
W. Edwards Deming
“Without data, you're just another person with an opinion"
My opinion JB is full of crap and Toyota did the right thing keeping a reliable 5 speed.
W. Edwards Deming
I admire your ability to take devils advocate to "n'th degree of Acehole". I don't fault anyone for stirring shit online, it's a good pastime.
That said, Jet boy is right on transmission and rearend gearing optimizing engine power. There's a reason we don't drive 3 speeds anymore and big rigs are all 10+ gears. He's posted supporting data, simply YELLING copy and paste doesn't make it irrelevant.
At any rate, you be you Boo Boo.:wave:
I admire your ability to take devils advocate to "n'th degree of Acehole". I don't fault anyone for stirring shit online, it's a good pastime. ....
Thanks.
That said, Jet boy is right on transmission and rearend gearing optimizing engine power. There's a reason we don't drive 3 speeds anymore and big rigs are all 10+ gears. He's posted supporting data, ....
Long stroke OTR diesel truck engines have a very different power curve and usage that the 4l 4R gas.
If a 6 was so much better than a 5 Toyota would have done it already Im sure but
cost vs perceived value to the customer
cost vs mpg added
cost vs additional warranty claims
cost vs CAFE
etc.
is what I would expect to see not hand waving and ""obviously its better" because it probably isn't.
Another poster said "just an additional $50 with of parts" .... thats HUGE in the automotive industry. It would need serious justification for even half of that.
I completely agree with you. As I stated in my first post, the issue is that people's perception of what the 4Runner is doesn't align with what Toyota made it to be. In the US, "off roading" really means rock crawling or mudding, whereas elsewhere in the world, it means overlanding/expeditions. This is more in line with what Toyota had in mind when giving the 4Runner off road abilities. Whether this US buyer misconception is a result of Toyota USA's marketing with the Pro line, or truly just uneducated buyers, who knows? I just think we have a community with many people who, for one reason or another, chose the 4Runner over a Jeep, but their goals off road were more in line with the Jeep's abilities, so they get buyer's remorse. If people took a minute to really lay their needs/wants out, then decide on a vehicle that best suits them, rather than just going for the flavor of the week vehicle that their favorite YouTube channel has, we'd have a higher percentage of satisfied buyers.
Case in point is Freedom Crawler on Youtube, that guy has gone through a handful of different vehicles trying to find the best off roader for his purposes, and while he does have a video about all the tradeoffs each brings to the table, it's obvious he needs to take his own medicine and just get another Jeep. Every so often he makes a video showing off his new vehicle (currently a TRDOR Tacoma) and why he loves it, etc. Then a couple weeks later, here comes a video about why it isn't as good as a Jeep at rock crawling, and rock crawling is really what he enjoys.
Instead of asking for data, can you prove his statements or math wrong? I feel that would be more fruitful to the conversation.
He's not waving His hands......it's FACTS! He is dead-on as to the benefit with no downside as the trans is already a reliable unit that is not being used to it's potential for the lack of $50 worth of guts inside. Better mpg would be a natural benefit of the increased torque through gearing but really it's the flexibility the gearing in the axle AND trans bring to the platform that would benefit larger tires and drive ability . Win Win for little investment. If the 1GR were tuned for a little less HP and more low and mid torque it would really improve the drivetrain IMO.
I'm assuming you've never actually taken your 4Runner off road? Or any vehicle? Get back to us when you try it. You'll probably understand a little more.
Also - I'm pretty sure you didn't actually understand the light info on the tacoma forum. OEM HID lights are quite different from aftermarket HID or LED bulbs in halogen projectors that were being compared. We're talking about OEM lighting updates. Not slapping a cheap HID bulb in a halogen projector housing.
Ok, I think we can all agree that RichinRidgewood is nothing more than an obnoxious internet troll. I haven't seen anything he contributes on here other than troll posts.
There's a few answers here.
The first - just to be clear - is that the 4.56/6AT combo would likely not improve mileage in a significant way. The engine rpms at highway speeds would be within 0.1% of what they are now - so less than 10rpm difference from the current transmission/axle combo we have now. It would effectively be exactly the same. In fact all of gears 2-6 on the 6AT/4.56 combo would line up nearly identically to gears 1-5 in the 5AT/3.73. The difference would simply be an extra lower gear in 1st gear. Driving it in city would literally be identical to driving a current 4Runner with 4.56 gears. Gears 1-5 are the same either way. If you ever get a chance to drive a current 4Runner with 4.56 - it's fantastic in the city. Initial launch is so much better. It's how it should be. But you run out of gearing on the highway. Going to the 6AT would add one extra gear for highway use that would put you back right to where it is now. The result is you get the improved city driving and keep the exact same highway cruising gearing. As it is now - you only get one or the other. You can't have both.
The result of that would probably be around a half second or better improvement in 0-60 (who cares about the time - but it would feel a lot quicker), better, easier towing.
With the 8AT - then we could see some real mpg benefits. The biggest one being that the drop from 8th to 7th gear is much less rpm difference from 5th to 4th gear in the 5AT. And often towing I end up dropping down into 3rd gear up most mountain passes. The torque converter won't lock up in any gears other than 4 and 5. So it's both creating a lot of internal heat, but also that's wasted energy. The 8AT in the same condition has more gearing options and will also lock the torque converter - less heat, better efficiency, and probably more power output by choosing the correct gear. So when you're going up a big hill, or you've added a bigger tire, or whatever you've done to increase drag or load by say 5%, then you dont' have to drop down a gear that's ideal for a 25% increase. You can change the gearing a small increment to keep the engine in it's best condition for the load.
The second problem we have is not gearing - its the engine. The 1GR simply isn't that fuel efficient and it appears to have a small window of high efficiency that does not, under any scenario, work efficiently at high output. So - for example - if all of the mods to the 4Runner, or a trailer, or ?? result in a requirement of say 100hp continuous output to maintain steady state cruising - it's possible, and I think is probable in our case, that the 1GR simply cannot produce 100hp at high thermal efficiency (good mpg). In that case if you still want 100hp for cruising, there's nothing you can do with gears to get great mileage. But - what you could do is maybe move from 14mpg up to 17mpg.
With an engine designed around a wider range of power needs - atkinson cycle, cylinder deactivation v8, turbo 6 all of those do the same thing, they change effective engine displacement, or potentially in our case just a larger engine, then you have the range of efficient output to handle things like higher loads well. The big failure IMO of the atkinson engines from Toyota is that they're just too small. They are a better way solve the problem of widely variable power needs than cylinder deactivation. But the 3.5L for example can either run as a 3.5v6 or it can run effectively at around 2.0L displacement. Functionally it's about the same as a 2.0l turbo. The two do the same thing, but in different ways. But what a Tacoma or a next gen 4Runner needs is not a turbo 2.0 that can also act like a 3.5L when needed. It needs is an engine that can be a 3.5L when needed or a 5.0L when needed. So it's a good engine. But it's the wrong engine for the Tacoma. You never need it to be a 2.0L. It's completely wasted other than at idle.
As a comparison with the Bronco - the 2.7 ecoboost can run anywhere from around 2.7 liters of displacement all the way up to probably 6 or 7 liters depending on boost. So, on demand it can act just like a 6 liter v8. And it'll be a very stark difference side by side when you compare one engine that has an effective range of displacement form 2.7-6.0 vs a Tacoma or new 3.5L 4Runner that is 2.0-3.5. Night and day. The comparable engine would be Toyota's 2UR. And frankly - that's what should be in the 4Runner and GX by now. That's the correct engine for efficiency and power. Even if you de-tune it to 300hp. Or a smaller version of the V35A turbo 6. Both engines have huge ranges of high efficiency in the power levels we want for lifted, loaded, towing etc.
So with respect to your tundra. The 5.7 is not very fuel efficient. And it really struggles with thermal efficiency at low output. So cruising empty - it get terrible mpg. Where it's most efficient is under higher load. My experience is that the Tundra actually does okay when towing heavy loads. It's just really out-dated. It's an engine from 2007 that has had no updates. It's a fantastic engine for durability. It's basically a big block (4.6" bore spacing) in GM terms and has lots of great features. But it's tuned very rich - presumably to keep cylinder temps down - and that's also probably why the supercharger actually increases mpg. Magnusson leaned out the fuel mix a bit. A re-tune could probably get 2-3mpg just by leaning it out a bit. But also it is way overdue for an update and apparently all reports suggest it's just going away. Supposedly they're building a stockpile right now of engines to finish out the Tundra models and then all v8's are going away and they'll switch to production of turbo 6 engines in the next few months.
So the tundra isn't so much a gearing issue. It's just an inefficient engine that's also combined in a truck that uses bigger heavier components than any other 1/2 ton, so it has a lot more parasitic losses throughout. The plus side is that you get huge running gear. The wheel bearings are bigger than an F250. The transmission internals are bigger and stronger than a GM Allison 1000. The rear diff is extremely strong. It has giant brakes. All of those things lead to a heavy truck that's not very efficient. Especially when combined with about a 20 year old engine. If the tundra had a 5AT and 3.73 diffs - it would probably be even worse.
The other consideration between say GM and Toyota is that you need to consider the total gearing. So transmission, transfer case, and differentials. I'm assuming everyone is currently using a 1:1 transfer case in high range (keep in mind that's not always true), so we'll ignore the transfer case for now.
If the transmission has a 4.7:1 first gear - and the axle has a 3.5:1 first gear, that's no different in effect from the differential having a 4.7 ratio and the transmission have a 3.5:1 first gear. The final gearing is the same in both. And incidentially it actually fits for this comparison with the GM truck. Both GMs 8AT and 10AT truck transmissions have a first gear of 4.7 or 4.56. And they are usually paired with a axle ratio of 3.55 IIRC. So that's actually exactly the same result as what I'm suggesting would work well in the 4Runner. The 1st gear is 3.5 in the 6AT and you'd match that with 4.56 diffs. Net - you'd get the same first gear ratio as GM's 8AT and 3.55 diff. If you compare to the Tundra - first gear is only 3.33 in the tundra 6AT and with 4.30 diffs, it's actually still a decent amount higher than GM. - in short the 2015 GM truck actually has lower net gears than the Tundra because the transmission is so much lower geared.
Now - just for fun, if you compared the Bronco 1st gear, it's 4.7:1 and the diff option is also 4.7:1. With our transmission - we'd need 6.3:1 differentials to match 1st gear in the Bronco. It's almost as low as the 4Runner in 4lo - while still in high range. And, still because the Bronco has a wide ratio 10 speed - it also has almost exactly the same highway cruising net gearing. In low range - the Bronco is soo much lower it's not really even comparable - it's better than my FJ40 would be with dual transfer cases and 5.29 diffs. Holy shit.
Yep. 700 posts worth of garbage since January.
Can't tell if he's trolling, or if we're watching a legitimate and severe example of Dunning-Kruger at work.
Cringeworthy.
Cringeworthy.
I know BS when I see it.
BTW this is a "forum" which would mean that people would have differing opinions.
Don't go waving your hands in the air talking about opinions. I'm going to need an engineer to pay me a personal visit to my home (not from the "net") to give me the data that backs your claim about "forums".
^^That's what you sound like^^
See there in lies the issue. JB has an opinion about "5 or 6" and fusses over gear size and tech stuff for pages and pages. My opinion is that only the business model matters and JB should fuss over that (provide the data proving that business model is wrong) of which he cannot do there for his "5 or 6" tech fussing's are meaningless.
Once again the business model (aka White Paper) would have this information below in one form or another.
cost vs mpg added
cost vs CAFE
etc.
I think that if Toyota can sell 140,000 4 Runners in its what 7th to 8th almost unchanged year of production that they know what they are doing and it does not need a 6 speed.
4 actually... 3rd gens haha. Friends and family owned
. Still not bad though.
You could have the 6speed transmission, the 4.6 liter V8, and 4.56 gearing without an overlanding compromise. The 6th gear would end up being no different than 5th gear on the 3.73 gearing but you would get a far better crawl ratio (for those that do more difficult off-roading) and better lower end acceleration (bye bye Sprint Booster).
And gas mileage, who really cares, it's a big SUV. I guess ultimately maybe that is why they put the V6 in the 4runner, slightly better gas mileage so they can eliminate some gas guzzler taxes. I guess Toyota doesn't care on a Lexus, it's expensive anyway.
Toyota has basically negated the crawl gear issue with crawl control. Where a physical gear with a specific "golden" ratio doesn't exist, advanced ABS control does. It's the same thing as LSDs vs. an open dif with brake biasing. The crawl gear/LSD is certainly better because it's a mechanical solution, but for 99% of situations the vehicle will be in, using the brakes will be sufficient, too.
All spec sheet bench racing aside, that "fact" of the matter is this; the 4Runner isn't the best at rock crawling, it isn't the most comfortable or nimble on road, but it does have the best compromise of on and off road characteristics of anything on the market now, in my opinion. It gives 99% of people 99% of the abilities they need, which is where Toyota wants to be to appeal to the most people and sell the most cars. There will always be the 1% of people who want something that's better off or on road, and for them there's the Jeep Wrangler or the Subaru Outback.
murphyl2022
