Toyotech boss lift
pabst
Member
Deciding to go with the boss lift. And going to do the lower ball joints. Is there any thing else I should do. Upper ball joints?
While I had my front end open I did the rack and pinion bushings with energy suspensions on the steering rack and upgraded the upper control arms to JBAs as well. As for extended brake lines I went with the wheelers offroad's extended brake lines and they've helped up fine.
Shouldn't need extended brake lines in the front, I got my rear extended brake lines from Sonoran Steel.
As for what else should you do, depends on how far down the rabbit hole you want to go. I've been going through my suspension and replaced basically every single bushing and ball joint.
Thanks for all the suggestions yeah I definitely want to replace all the bushings that I can and get everything like new. I've been wanting to lift this for 8 years so pretty excited
Jesse1
