Toytec/Eibach 112-620 Front Coil Lift Springs Pics
SoFloT4Run
Does anyone have any pics of their trucks with these coil springs installed?
I'm really looking to see if there is any difference in height between a bilstein 5100 adjustable set at 1.75 with an OEM coil spring and this coil spring which claims to lift our trucks by 1.6 inches utilizing either Bilstein 5100's set at the lowest perch setting or an OEM shock/strut.
I have found some pics online of FJCruisers using this coil setup and ultimately achieving a 1.4inch lift after the coils settle but I haven't found any pics of 5th gen 4runners using this specific setup.
I don't think anyone would recommend you run a stock OEM shock with a taller coil spring. You will be topping out the shock constantly and will ruin it in short order.
Yea you are right about the OEM schock, I guess I meant a non-adjustable performance shock like Dobinsons or other comparable brands.
