Gerdo
I did an alignment when installing my complete OME kit. Does anyone think it necessary to do again after replacing just the rear coils and rear shocks?
In theory, changing the height of the rear does effect the front alignment. As the back goes up, the caster is reduced. Also as the back goes up, the rear axle will move to the passenger side. This movement does change the tracking of the vehicle. If you don't do an alignment you may notice the steering wheel might be off center. This does not effect the alignment. You may also notice a slightly "lighter" steering feel due to less caster. Neither is something that NEEDS to be corrected.
Driving with a heavy load in the back of the vehicle also, except in reverse, effects alignment in the same ways.
From personal experience. I have changed rear coils without getting a new alignment.
Changing out the rear shocks will not effect the alignment at all.
